eCart5
Thread begun 4/01/2010 2:34 pm by dave403891 | Last modified 4/09/2010 4:21 pm by Jimmy Wu | 5189 views | 11 replies |
dave403891
eCart5
I'm stumped. I'm using DWCS4 on os10X I've installed the extensions, created a database,table/rescordset, but I don't seem to be able to use the add to cart button to get anything to show up in my eCart. How do I link to my table and get eCart to function? I'm not even sure of the questions to ask. Help!
Jimmy Wu
Have you tried following the getting started guide for eCart? It steps you through the process:
ecart_gsg.php
On the support page for eCart, there are other useful tutorials as well:
ecart/
dave403891
Working with images
Jimmy, Huge thanks. If all else fails read the directions, but I couldn't find anything there that explained how to get images in the recordset I used with my add to cart buttons to show up in the cart. In the browser all I get is a placeholder with a question mark in the middle. Your thoughts please.
Jimmy Wu
In your eCart object, under columns, there should be a column called Thumbnail by default. In the add to cart button, under the bindings tab, you will have to bind the thumbnail to the recordset value that holds the location of the image you want to use.
dave403891
Image path
Jimmy,
Thanks again. Here's the path I enter before the <?php:
book_covers/cart_thumbs/
This renders as:
book_covers/cart_thumbs/<?php echo $eCart1->DisplayInfo("Thumbnail"); ?>
I've tried adding both
images/ and assets/images/ to this string and nothing loads the image into the cart. I've checked spelling. Once I crack this code, I'm home free.
Jimmy Wu
An easy way to figure out what path needs to be added to the image name in the binding is to navigate to the image directly in the browser. Then when you get the broken image, get the image location and see what the difference is. The image path should become apparent at this point.
dave403891
Here's the path code from both the add button binding and the cart src
This is the code from the add to cart button=
http://localhost/ic-site.2/assets/images/book_covers/cart_thumbs/carcapkid.png/<?php echo $row_rsCartadd['Thumbnail']; ?>
This is the code from the cart-
<td class="eC_GroupColumn"><img src="http://localhost/ic-site.2/assets/images/book_covers/cart_thumbs/" alt="" class="eC_ProductThumb" />
When I double click on the broken link icon in the cart the folder containing the cart thumb image files opens. I will be a wiser man when all this is resolved. Thanks for sticking with me.
dave403891
Tried this too
In desperation, I deleted both the cart and books file where I had added the add to cart buttons. After recreating these .php pages, I entered the code just as instructed. Nothing. Because I have a deadline, I'm moving forward without the images on the shopping cart page. I figure I can go back once I've figured out what's wrong and add the images code later. In the meantime I really do want to know how to accomlish this.
Jimmy Wu
What is the path to the images directory and how would you access the images in the browser?
dave403891
Jimmy,
This gets me to my images folder in the browser–
cart_thumbs
When I configure the add to cart button, I replace the default value with the following code–
assets/images/book_covers/cart_thumbs/carcapkid.png<?php echo $eCart1->DisplayInfo("Thumbnail"); ?>
The carcapkid.png is the image file in the recordset for this particular ID
