Date and Time to UK settings
I am in the UK and it it possible to change the time and date settings to UK time. Currently on all orders etc it is showing US time.
Thanks in advance
Robert
Thanks in advance
Robert
Hi
yes it's possible but I would suggest you take loads of backups "just in case"
If I get a chance I'll try this myself but what I did was search all the code for
mm/dd/yy and change it for dd/mm/yy I found seven entries.
As to the time issue I'm not sure what you mean.
HTH
Ian
Thanks I will give it a go, date that is.
The time is shown on the order history etc and is set to US time not ours.
Thanks again for the date issue
Robert
Hi
not 100% sure but I would suspect the time comes from the PHP server which will be set to where ever it is.
HOpefully support will supply a definative answer
HTH
Ian
Yes, the sql server time used is the time of the operating system on which it is installed. If you are using a US host, then the time is probably set to a US time. They may be able to change the time for your machine if you contact them.
Great, if you run into any additional issues, feel free to open a new thread.
