Javascript error!
Thread begun 4/01/2010 11:20 am by olle189996 | Last modified 4/20/2010 5:38 pm by Jimmy Wu | 3395 views | 6 replies |
olle189996
Javascript error!
Hi
Just upgraded from Irite to HTML editor.
I get an error when trying to activate the global file permissions.
Is this the usual "reinstall all webassist extensions" problem?
Or is it another (see att)
Using Mac and latest 2.01 (beta)
Regards
olle
olle189996
Hi
Just tested with clean confiq folder. problem is still there.
Great update!
regards
olle
Jimmy Wu
Have you tried deleting the winfilecache file?
Did you mean you are installing a beta version of the HTML editor? Try installing a non-beta version.
olle189996
Well yes I have. with a clean confiq folder I meant starting over with reinstalling all extensions.
The Macfilecache file resides in that folder on a mac.
Hoewer I found the soulotion. I had a databasefield with the name of "url". Renaming that solved the problem.
Is "url" some sort of reserved word for HTML editor?
Regards
olle
Jimmy Wu
I'm not sure if url is a reserved word for HTML Editor. I'll have to look into the reason why having a database column called url will cause an error.
dave315749
same problem
i had a form with a text box called url and it did the same thing spent like 3 hours trying to fix it... ahhh !!
Jimmy Wu
Sorry for the inconvenience. This issue is being looked into currently.
