While Executing timer in WA_iRite_Preset.html a Javascript error occurred
Thread began 3/31/2010 8:04 am by billjones325536 | Last modified 3/31/2010 4:43 pm by Eric Mittman | 688 views | 1 replies |
billjones325536
When using html editor and then clicking Customize I get the error: While Executing timer in WA_iRite_Preset.html a Javascript error occurred
Have to force quit dreamweaver
Have deleted .dat file and also restored Dreamweaver configuration file to sometime before the problem occurred.
Do you know how to fix this?
When you delete the dat file you will need to ensure that DW is closed. Also, a reboot of your machine may be in order.
If after doing this you still get the error you will need to rename the configuration folder to undo any corruption that may be present, here are the steps you can take for this:
showpost.php?p=12293&postcount=2
