Problem with Data Assist Persist
Thread begun 3/30/2010 8:45 am by Gabriel Tiviroli | Last modified 3/30/2010 12:45 pm by Gabriel Tiviroli | 2548 views | 3 replies |
Gabriel Tiviroli
Hi, Jason, first of all sorry for having rushed, there is a waiting period, but sometimes the trouble we win! : (. Well, the point is that the problem persists and I continue with dataassist errors because I checked everything and I see at least me, the problem. So I decided to take screenshots of everything so that you can help, the truth I'm lost and I know that only with your help I can pull this off. I hope you used the material sent to you in that way we can achieve a final settlement. Thank you from now and hope the problem is resolved. Sorry for my bad english, im from Argentina. Please help me, not only i´am a subscriber of the extension library, but also I bought almost all the software they provide.
the problem is that some of the columns in the insert and update record behaviors have the data type set incorrectly, for each of those columns, you will need to reset the data type.
I am including a screen shot showing the problem.
Gabriel Tiviroli
But, the problem is in the database or the insert or update registration wizard?
Gabriel Tiviroli
Thanks!
Thanks the problem has been solved, sometimes the simplest mistakes are the most noticeable to a novice like me! thanks again
