Set session
Thread begun 3/29/2010 5:29 pm by nickj | Last modified 3/30/2010 6:26 am by nickj | 1935 views | 4 replies |
nickj
Set session
I've worked all day on this with no luck. I need the detail page to have a session variable of the record ID just like "$_SESSION['WADA_Insert_tblVendors']". Unfortunately "$_SESSION['WADA_Insert_tblVendors']", which appears in the bindings Session and can be dragged onto the page, but will not work to filter a record set.
I need to create several additional recordsets based on it. ADT I could set a custom trigger to collect the record ID and pass it to a session variable.
Nick
Russell CollinsBeta Tester
record ID
The "$_SESSION['WADA_Insert_tblVendors']" is used on the insert page as there is no record in the database to view until the insert behaviour has occured (to enable any filtering).
After that point you could filter the recordset by the record ID using URL as in "record ID = URL parameter" this is in the simple view of the RS or if its going to be a set record ID use
"entered value"
If you are trying to add and view information to lookup tables your better to use the manage relational table behaviour. If you have 3 tables. Main, second and then the 3rd table(lookup) with info from both main and second
Regards
Russ
nickj
Thanks for your quick response. The "$_SESSION['WADA_Insert_tblVendors']" appears in the detail page of the WDA set, it appears as a session variable but is not able to filter a record-set.
On the detail page I need to use a look-up table which, depending on the date will give a price. The query below should return a result only if the created date is before '2010-03-30 23:56:16! It returns a results for records later than the 30th.
I Also tried to edit the record-set but the filtering on "dateCreated". It did not work, it returned a result even for records with a date later than tblVendors.dateCreated = '2010-03-30 23:56:16'. In SQL this works but not on the page. WADA is doing something else altogether.
"SELECT label.descr_lbl AS electric
, vendorType.descr_lbl AS vend_type
, non_pro.descr_lbl AS Non_Profit
, vendorType.pre30_ven AS Pre30
, label.value_lbl AS Elec_qty
, tblVendors.*
FROM (((tblVendors
LEFT JOIN label AS non_pro ON non_pro.value_lbl=tblVendors.nonProfit)
LEFT JOIN vendorType ON vendorType.value_ven=tblVendors.vendorType)
LEFT JOIN label ON label.value_lbl=tblVendors.electric_ven)
WHERE label.group_lbl=4
AND non_pro.group_lbl=4
AND vendorType.group_ven=1
AND tblVendors.dateCreated = '2010-03-30 23:56:16'
AND tblVendors.ID = %s OR ( -1= %s AND ID= %s)",
primary key on main table
Once the data has been inserted from the form with the "$_SESSION['WADA_Insert_tblVendors']" it should be the last time you use it, its that "$_SESSION['WADA_Insert_tblVendors']" data that has now been inserted into the db as its primary key (VendorsID).
So any other pages need to now reference (or filter) this primary key "VendorID" now stored in your main table not the one that is temporarily created on the insert page.
Regards
Russ
ps have you successfully used "manage relational table" in DA before ?
nickj
Thanks Russ, no I haven't used "manage relational table" .Is this Webassist behavior still available?
Nick
