error
C:/xampp/htdocs/xxxx/HTMLEditor/editor/dialog/skins, referer: fck_colorselector.html
hi this is an invalid path HTMLEditor do not know how I can help correct
Are you using the file system path for your user files setting? If so you should put in a relative path to the user files from the root of your site. So if the userfiles are in a folder called files you would set it like this:
"files/"
If this is not what you are referring to please post back with some more info so we can help you out with this.
