Shipping charges on Specific Line Items mapping to PayPal
Thread begun 5/21/2009 7:51 am by randy294090 | Last modified 5/22/2009 8:36 am by randy294090 | 3991 views | 4 replies |
randy294090
I have added per item shipping charges to my static eCart object and input the per item charge in the bindings tab when creating the button button.
In the cart the shipping charge show in the line item columns, totals in the line and in the Total Charges for the order.
But the line item shipping charges do not transfer to the PayPal totals. I am using the Website Payments Standard.
How do I get the line item shipping to map over the the PayPal line and order totals?
Here is the site and you can test if you wish.
11thstepmeditation.org/
Thanks,
Randy
You need to add the shipping charge to the price in the hidden form element where it is being passed to paypal.
It should be in one of the form elements inside the DO loop for the cart. You will see it is set to the Price column and would need to be updated to add the Shipping column to that price so that paypal will think the total is correct.
You could either do the math right there in the hidden form element, or add a calculation to the cart: PaypalPrice = [Price] + [Shipping]
Then just refer to the PaypalPrice when passing to paypal.
randy294090
Hmmm....not sure what DO Loop is. This code below is on my confirm page and looks like it is the data that is passing to PayPal. Is this correct and would you mind showing what line to add the shipping column to the price?
<?php //WA eCart Validation
if ((WA_eCart_FormatNumber($eleventh_step_store->DisplayInfo("Price") - (($eleventh_step_store->DisplayInfo("Price")/$eleventh_step_store->TotalColumn("TotalPrice")) * $eleventh_step_store->GetDiscounts()), false, 2) > 0)) {
<input type="hidden" name="amount_<?php echo $eleventh_step_store_Index+1; ?>" id="amount_<?php echo $eleventh_step_store_Index+1; ?>" value="<?php echo WA_eCart_FormatNumber($eleventh_step_store->DisplayInfo("Price") - (($eleventh_step_store->DisplayInfo("Price")/$eleventh_step_store->TotalColumn("TotalPrice")) * $eleventh_step_store->GetDiscounts()), false, 2) ?>" />
<input type="hidden" name="item_name_<?php echo $eleventh_step_store_Index+1; ?>" id="item_name_<?php echo $eleventh_step_store_Index+1; ?>" value="<?php echo $eleventh_step_store->DisplayInfo("Name") ?>" />
<input type="hidden" name="item_number_<?php echo $eleventh_step_store_Index+1; ?>" id="item_number_<?php echo $eleventh_step_store_Index+1; ?>" value="<?php echo $eleventh_step_store->DisplayInfo("ID") ?>" />
<input type="hidden" name="quantity_<?php echo $eleventh_step_store_Index+1; ?>" id="quantity_<?php echo $eleventh_step_store_Index+1; ?>" value="<?php echo $eleventh_step_store->DisplayInfo("Quantity") ?>" />
<input type="hidden" name="on0_<?php echo $eleventh_step_store_Index+1; ?>" id="on0_<?php echo $eleventh_step_store_Index+1; ?>" value="" />
<input type="hidden" name="os0_<?php echo $eleventh_step_store_Index+1; ?>" id="os0_<?php echo $eleventh_step_store_Index+1; ?>" value="" />
<input type="hidden" name="on1_<?php echo $eleventh_step_store_Index+1; ?>" id="on1_<?php echo $eleventh_step_store_Index+1; ?>" value="" />
<input type="hidden" name="os1_<?php echo $eleventh_step_store_Index+1; ?>" id="os1_<?php echo $eleventh_step_store_Index+1; ?>" value="" />
else {
$eleventh_step_store_Index --;
This is the correct spot. Are you using discounts? The line in question is:
You can update it to something like:
id="amount_<?php echo $eleventh_step_store_Index+1; ?>" value="<?php echo WA_eCart_FormatNumber($eleventh_step_store->DisplayInfo("Price") + $eleventh_step_store->DisplayInfo("YourShippingColumnName"), false, 2) ?>"
randy294090
That worked! Thanks for your help, Ray!
