Failing to successfully add a ribbon gallery to a PowerGallery product's detail page
Thread begun 3/29/2010 11:46 am by neilo | Last modified 4/03/2010 9:26 pm by neilo | 6004 views | 10 replies |
neilo
I am failing to successfully add a ribbon gallery to a PowerGallery product's detail page. I start with a functioning store. Test products are entered, and their detail pages show fine. I have posted the problem previously, but received no advice.
To add the (PowerStore) PowerGallery to one of these items I do the following:
1. I upload the file wa_evaluate.php to the directory (store) that holds all my PowerStore files and folders. My Power Gallery folder is also located in this folder.
2. The instructions say, "Open the page that will display your PowerGallery from a database" so I open the Products_Detail.php page in the store's root directory.
3. I find the line, <div id="ProductLongDesc"><?php echo $row_WADAProducts["ProductLongDesc"]; ?></div>
4. As per instructions, I change it to:
<div id="ProductLongDesc"><?php require_once('wa_evaluate.php'); ?>
<?php echo wa_evaluate($row_WADAProducts["ProductLongDesc"]); ?></div>
At this point - each and every time - the site 'breaks'.
5. Carrying on regardless, I create the 'Ribbon + Lightbox for PowerStore (light)' gallery.
6. I select a product, click to update it, and in the source code view of the Long Description editor area, I paste the code from the PG 'Add to site' > 'Add to PowerStore' area:
<input type="hidden" name="powergallery" id="1" theme="light" value="/home/users/uks66722/html/206bones.co.uk/store/gallery/galleries/ribbon_lightbox_powerstore/index.php" />
7. Save the changes.
8. View the disaster that is the product detail page, as I have on several previous goes and on different PowerStore installations.
I can see the very top of the inserted gallery on the product detail page along with the error message:
*Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/users/uks66722/html/206bones.co.uk/store/Products_Detail.php:1) in /home/users/uks66722/html/206bones.co.uk/store/WA_eCart/WA_eCart_Definition_PHP.php on line 480
I have done the usual 'Cannot send session cache limiter - headers already sent' checks.
I have seen other peoples' successful implementations, so am aware that I have messed up somewhere. Please could somebody write out the instructions on how I should be implementing the ribbon_lightbox_powerstore gallery for a product, or suggest where I am going wrong?
Instead of adding the power gallery code to the PowerStore/Products detail page, you should add it to the long description when editing the product on the PowerStore/Admin/Products_Update.php page.
Log into the admin section of power store, then search for the product you wish to display the gallery for and click the edit button.
In the Long description field on the update page, change the HTML editor instance to code View and paste the PowerGallery Code. Then save your changes.
neilo
Yes, but that's what I'm doing already. See Nos 5 - 7 above.
so the real problem is that you are getting the headers already sent error, looking at your page, it looks like the gallery is there, just not displaying because of the error.
the error message is reporting the output at line 1:
this usually happens if the page has been set to Include Unicode Signature (BOM). Go to File -> Save As. In the Save As Dialogue box, uncheck the Include Unicode Signature (BOM) option.
if you still have a problem, please send a copy of your Products_Detail.php page.
neilo
Hi Jason, once again you were spot on. Everything is working just as it should now.
For some strange reason, un-checking the 'include unicode signature (BOM)' and 'Saving As' didn't seem to 'take', - (in the Powerstore files this option seems to be 'always on') but opening a new blank page (my Dreamweaver preferences 'New Document' always has the 'Include Unicode Signature' switched off) and copying and pasting in the Products_Details page code then saving that seemed to work. (No idea why!).
So yet again, am grateful for the 'rescue'.
Many thanks.
Odd. My power store files do not have the 'include unicode signature (BOM)' setting enabled, strange that yours do.
At least you found a good work around copying the code to a new page, glad to hear it is working.
dave378160
I've read this thread up and down and I seem to have gotten close to getting it but I just can't figure out where I'm goofing up. Here is a link to what I've been able to get so far.
Products_Detail.php?ProductID=2#
I get this First Next Last Prev loading... text below the image.
Also, If I'm using PowerGallery to show the images, do I need to upload Detail and Catalog images? I'm not sure if that's what's causing my problems or not.
neilo
Hiya Dave,
A couple of observations, for what they're worth.
I notice that you are trying to include the 'Ribbon + Fullsize + Lightbox' in the detail for your item. Perhaps you should stick to using the 'Ribbon + Lightbox for PowerStore' - as it was purpose-made for putting in to PowerStore product detail pages.
Also, the paths on your page to the required components seem to be missing part of the path: i.e:
@import url("css/slimbox/slimbox.css");
@import url("css/common.css");
@import url("css/light.css");
<script type="text/javascript" src="js/mootools-core.js"></script>
<script type="text/javascript" src="js/mootools-more.js"></script>
<script type="text/javascript" src="js/slimbox.js"></script>
<script type="text/javascript" src="js/gallery.js"></script>
The /powergallery/galleries/ribbon_lightbox_powerstore/ part of the paths is missing (assuming you will be using the 'Ribbon + Lightbox for PowerStore' gallery).
I think you should swap over the type of gallery to 'Ribbon + Lightbox for PowerStore' and then click the 'Add to Site' button and copy the code from the code block in the 'Add to PowerStore' area at the bottom of the page to the the source view of the Long Description editor area in the product's update page.
The code you should be given by the 'Add to Site' page should be something like:
<input type="hidden" name="powergallery" id="1" theme="light" value="/full/sever/pathto/yoursite/thegraphiclibrary.com/shop/powergallery/galleries/ribbon_lightbox_powerstore/index.php" />
The bit in grey will be different, being particular to your site.
Cheers.
dave378160
Thanks Neilo, I will try that tonight. Going to start from scratch with the PowerGallery. Not sure if one of my problems was the fact that I moved the PowerGallery folder into the shop folder after I went through the install wizard.
dave378160
Thanks for the help neilo, it worked. I was missing the PowerStore part of the ribbon lightbox. I was picking the wrong one. Once I reinstalled the powergallery and started over, it worked without any issues. Woot! sooo happy.
