Update Multiple Records - When will it be fixed to work with Tables?
Thread begun 3/28/2010 9:00 pm by Jaffa | Last modified 3/29/2010 12:57 pm by Jason Byrnes | 1169 views | 1 replies |
Jaffa
There is a logged bug with the Multiple Record Update when used with a table as seen throughout this forum, any idea when this will be fixed.
I know you can get around the issue using divs but I prefer to use tables for repeating data, as they are intended for.
Cheers.
This will be fixed in the next update DataAssist. I do not have a time frame for when that will be however.
If you send me a copy of your page, I can tell you how to work around the problem. basically, there is a line of code that needs to be moved so that is inside the repeat region code.
