PowerCMS path confusion new version
Thread begun 3/28/2010 5:12 pm by admin140217 | Last modified 3/30/2010 5:09 pm by Eric Mittman | 4804 views | 8 replies |
admin140217
Hi All,
I'm a little confused. I just updated to the latest PowerCMS version and the output path has changed when saving a new area.
Example:
I just inserted new information to a new page and the output PowerCMS is giving me to place into the site is
include('C:/xampp/htdocs/daddyshome/CMS/WA_CMS/addtosite.php');
echo WA_getCMSContent($database_localhost, $localhost, 'Home' , 'local_groups');
Although this works locally, this is an absolute path and I thought PowerCMS wroked with reletive paths?
Previous output used to be:
<?php echo WA_getCMSContent($database_localhost, $localhost,"Links", "General_Links"); ?>
Can someone explain this to me?
neilo
What directory are your PowerCMS files and folders in on your remote site?
If it is in a folder called 'CMS' in the root of your remote site, then your WA_Globals.php would look like:
$WAGLOBAL_Site_Name = "Your Site Store Name" ;
$WAGLOBAL_localRoot = "/WA_CMS/"; //relative path to your PowerCMS files on your local testing server.
$WAGLOBAL_remoteRoot = "/CMS/"; //relative path to your PowerCMS files on your remote server.
// Admin Settings
$WAGLOBAL_Admin_UserName = "yourAdminName" ;
$WAGLOBAL_Admin_Password = "yourAdminPassword" ;
On the WA_Globals.php file uploaded to your remote server, you may as well put your remote CMS folder name as both the $WAGLOBAL_localRoot and $WAGLOBAL_remoteRoot names.
The globals file is the same in Version 102 as it was in 101.
admin140217
Neilo.
Right now the site is only local until I am done deveolping it and the CMS folder called "CMS" is in the root of the site directory...
/mysitedir/CMS/
I have both localroot and remoteroot set to this path currently.
Is this incorrect?
Thanks for the reply!
neilo
Hi Admin,
No, not at all - if 'CMS' is in the root of both local and (eventually) remote sites, then that is spot-on.
admin140217
Thanks Neilo,
I am still a little confused at the CMS output string and why it is in an absolute form instead of relative.
Are the relative paths only for setup purposes in the WA_Globals.php file only while the output string on the CMS is absolute?
Doesn't this mean that the path will need to be changed once everything including the database is uploaded?
neilo
I'm absolutely the last person to be talking about this, but no, you shouldn't have to update the paths when you upload to the remote server.
The localroot and remoteroot globals are indeed relative to the site root, but that is (I think) determined by the (__FILE__) (and realpath) functions in the addtosite.php file.
When you use the same globals file on your remote server, it will also create an absolute path based on the realpath + (__FILE__) + global root values, so your include code will turn into something like:
include('/home/users/ukr86294/html/yoursite.co.uk/CMS/WA_CMS/addtosite.php');
depending on how your remote server paths are cofigured.
But hopefully an expert will add to that.
When you view the cms pages in the admin area the code that you see to add it to a page will be specific to the server you are on. So if you upload this to your live server it should adjust the paths to work for your server without having to make any edits. I confirmed this with a test where I went from my local testing environment and uploaded to my live linux server, I just ported the db over and all was fine.
admin140217
Neilo,
Thanks for your replies, I'm a novice when it comes to PHP and although I can work my way into understanding things, sometimes it's just to confusing.
Eric,
This is good to know, hopefully when I am ready to upload all this, I won't have an issue. Right now with the exception of one issue I'm having with viewing images in the CMS, everything is working as it should.
P.S. I already have a support ticket in for the image issue.
Ok, if you have any other questions in the mean time let us know.
