The Upload Files_WA script does not define the findServerBehaviors function
Thread begun 3/28/2010 12:49 pm by larry268887 | Last modified 3/29/2010 8:25 am by Jason Byrnes | 2002 views | 2 replies |
larry268887
I installed DFP2 after UE4 was installed. After learning that you can't have both installed I uninstalled DFP2 and UE4 and reinstalled UE4. Now when I load the php page I get the following error: The Upload Files_WA script does not define the findServerBehaviors function.
How do I correct the problem?
larry268887
CS3 problem solved
Cs3 is now working. Had to uninstall WA extensions and reinstall and delete cache file.
Now I'm back to the original problem. the following error is received:
Fatal error: Call to undefined function imagecreatefromjpeg() in C:\webserver\Apache2\htdocs\purpleshoes\webassist\ file_manipulation\helperphp.php on line 865
How can this be corrected?
you need to enable the GD library in the php.ini file.
