deleting level 3 deletes the main level aswell
Thread began 3/27/2010 7:58 am by sales377016 | Last modified 3/29/2010 11:46 am by Eric Mittman | 1078 views | 2 replies |
sales377016
Hi
Ive created a horizontal menu with 1 level (main + 1 level). when i go into theme - define, there is an extra level, level 2. when i click on level 2 and delete then click apply, the main level deletes and level 2 plus all the design is lost?
plus i dont know if this is the way the extention behaves normally but it is very very slow!
neilo
I have also found that if you delete the level three (css) from the 'theme' view, it will also delete a level above it when you apply.
To change the menu structure, you should do it from the 'Edit Contents' area (not 'Edit Theme'), you can add or delete levels successfully there.
I don't find CSS MenuWriter to be particularly slow, so not sure what that problem might be.
Let us know if you continue to have problems with the setting or menu structure after trying it like this, also when you say it is very slow are you referring to the preview or when making changes? Please let us know so that we can help you get past these problems.
