Modifying an existing form
Thread begun 3/26/2010 12:29 pm by woodenboat | Last modified 4/15/2010 3:39 am by john275907 | 2370 views | 4 replies |
woodenboat
I have an existing form I created and would like to add captcha to it. I put my cursor inside the form, select webassist > css form builder > insert form. When I do this I get this error: A Runtime Error has occured. Do you wish to Debug?
Line: 367
Error: Expected';"
why?
I'm also getting errors even when I start a new form using css form builder and select one of the existing template forms Log in.
"While executing onResize in WZ_SiteTools_Progress.htm, the following JavaScript error occured:
In file "WA_SiteTools_Progress":
refreshUI is not defined
and another
While executing onClick in WAFB_AddForm.htm, the following JavaScript error occured...
I'm not sure what would cause that error. I've created a support incident so that we can look into this problem with you directly.
Please update your incident in the support history section of our web site to include a phone number and good time to contact you and we will try to get this resolved as soon as possible.
Maybe include a copy of the page so we can see if we can reproduce and fix the problem without needing to call you at all.
woodenboat
I did delete dreamweavers cache thinking that might solve the problem which did solve all the errors except for the Runtime Errors but I managed to add the captcha. The big problem for me is CSS form builder edits ALL the fields in the form and creates/adds validated code to ALL fields when I don't want it, too much bloat/code added to areas I didn't want edited. I would like to be able to just add some security and validation to a couple of fields and then use universal email to set it up for submissions.
This is a common request. We will investigate ways to make that easier in the future. Thanks for the suggestion.
john275907
Modify Existing form
I second woodenboat's comment about being able to make a simple addition to an existing form such as adding captcha. This was the main reason I purchased this product.
At least woodenboat got his form to work......
