autmatically displaying tooltip information
Thread begun 3/26/2010 9:43 am by jfrasier251038 | Last modified 4/01/2010 2:35 pm by Ray Borduin | 5051 views | 9 replies |
jfrasier251038
I would like the tooltip containing my clients address to display by default on the map, rather then having to click on the flag. How would I accomplish that?
Do you have a sample page? That would allow me to figure out the exact line of code to update in order to solve the problem.
jfrasier251038
Can I PM or email it to you? At the moment it is behind a secure folder login, and I don't want to give up the login info for everyone to see. Actually I posted a secondary copy to the site so you can review it
contact2.php
find:
if(!fromAddress.enabled || 'address_0' != 'address_0') {
if('address_0' == 'address_0')
map.setCenter(point, 13);
map.addOverlay(new GTrafficOverlay());
map.addOverlay(marker_0);
and change it to:
if('address_0' != 'address_0') {
(I only updated the first part so that it shows the window even when directions are present)
jfrasier251038
Ray,
Thanks for the code snippet. But I located and replaced the code in the wagmp_map_1.php file and it is still only showing the address window on click. I attached the php file, the code that was replaced starts on line 210
Do I need to clear the cache folder?
Let me see it on a live page. It is hard for me to debug if I have to set up a site for testing.
jfrasier251038
Ray,
NP, it is the same page as I provided for the directions not displaying:
contact2.php
It appears one more place in the code..
if (!fromAddress.enabled || 'address_0' != 'address_0') {
should be updated to:
if ( 'address_0' != 'address_0') {
neileisen207079
I dont think that works
I tried your solution, because I too, wanted the marker info to be open when the page initially loads. My client didnt even know it could be clicked. I know this can be done, but it has nothing to do with whether or not directions are displayed. I just want the marker to be clicked open when the page first loads. Can you do that? I tried the solution above and it didnt work. I only had one instance of that code.
Please post a url to the page where you are having trouble and I'll try to give advice on how to fix it.
