No verification email being sent
Thread begun 3/25/2010 6:28 pm by WilliFixit | Last modified 3/31/2010 11:09 am by Jimmy Wu | 5005 views | 10 replies |
WilliFixit
I just installed the URSP. I am able to get to the register page (users_Registration.php) and enter all the information.
When I click the Register button, it accepts the information, and returns to the same form, which is now empty. No verification email is sent, and I am not sent to the users_ThankYou.php page. The page is updating the database with a new record with all the information, so the database connection is working fine.
If I try to log in (users_LogIn.php) I just redirect back to the same page after entering correct login information. The same thing happens if I enter a bogus email/password.
If I go to the forgot password (users_EmailPW.php) and enter an email address that is in the database (registered but not verified) I DO get an email with the login password.
I have not changed anything on the original files except the WA_Globals.php, but I did apply my site template to the original PHP files. One concern that I had was that when I was applying the template, I was prompted with a dialog titled "Inconsistent region names" which wanted me to resolve two regions: Document body and Document head. I resolved the Document body to "content" and the Document head to "head". That applied the template correctly, but I don't know if that messed something else up.
Hoping for help soon...
This is probably due to the trigger we are using. We do referrer checking as part of the security routine to make sure the page was submitted to itself to prevent form spoofing.
Sometimes (I'm guessing in your case) firewalls or security settings block the referrer from being read in.
Solve the problem by replacing:
if ((($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)))     {
with:
if ((($_SERVER["REQUEST_METHOD"] == "POST") && isset($_POST) && isset($_POST["Register"])))     {
WilliFixit
Thanks, Ray,
So, are there any other PHP pages (besides the registration page) that I should change this code?
do a search on your site for:
"$_SERVER["HTTP_REFERER"]"
you will probably have to update it and remove it wherever it is used if that is the problem.
WilliFixit
Hi, Ray,
I replaced the code, commenting out the original as follows:
/*if ((($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST))) {*/
//WA Universal Email object="mail"
//Send Loop Once Per Entry
$RecipientEmail = "".((isset($_POST["UserEmail"]))?$_POST["UserEmail"]:"") ."";include("WA_Universal_Email/WAUE_users_Registration_1.php");
//Send Mail All Entries
if ("users_ThankYou.php"!="") {
header("Location: users_ThankYou.php");
The search found three files:
  • users_LogIn.php
  • users_Registration.php
  • users_Registration_Simple.php
Unfortunately, I still do NOT get a verification email on a new registration (but new record is added to the database) and I am not redirected to the "thank you" page. And if I try to log into the account (which is in the database), I cannot...the login screen just clears my entries and reloads.
What should I try next?
I have opened a support incident related to this issue. We will have to debug it to see why it isn't sending. The updated code looks correct.
maybe simplify it even more and update it to:
if (isset($_POST["Register"])) {
Please update your support incident with contact information and we will get in touch with you as soon as possible (early next week).
WilliFixit
Suggestion for changing code to simply:
did not change the result.
It has to be redirecting before it gets to that line of code then.. maybe a go to page set on the insert.
WilliFixit
Thanks Ray, but since I don't code (reason why I purchase the WA stuff) this doesn't help me.
There was a support ticket opened up last week but I have not heard from anyone. Any updates?
Jimmy Wu
I responded in the ticket and will be giving you a call shortly.
