discount coupons apply to certain items
Thread begun 3/25/2010 4:42 pm by sandyrumsey378810 | Last modified 3/15/2011 10:00 am by Jason Byrnes | 6015 views | 15 replies |
sandyrumsey378810
When people enter the discount code on the website , they will receive 20% off of the titles that are in the attached ad. So, I want the custom trigger to compare the item Number of each item with the list of items in the ad. What is the correct syntax for that?
In powerstore you can browse and pick items for coupons to apply to.
If you are doing this manually in eCart and don't have a database driven coupon system like what powerstore uses, then you would probably have to do it manually.
You could add a column to your shopping cart for "coupon_applicable" and set it to "1" for items that are included in the coupon and "0" for items that aren't. Then you can create a calculation for:
discountedTotal = [Quantity] * [Total] * [coupon_applicable]
Then base your coupon on 0.2 times the total of that calculated discountedTotal column.
There are really a million ways you could do it depending on the complexity of what you are doing. Do you have multiple coupons like this each that apply to different groups of items? How often do the coupons change? At some point couponing can be very complex, but it all depends on the specific details of what you need.
SaladoGuyBeta Tester
I want to do something similar to this...
I've got 6 extra columns in my shopping cart for 3 groups of optional accessories.
So there are two columns for each accessory group, one for the accID and one for accPriceIncrement.
The discount that I want to apply is 50% off of any accessory (accPriceIncrement) that is in the cart, if someone enters a specific coupon code.
I have all of the code working for the coupon input, (I have several simple coupons setup that are working great).
I just don't understand how to make a discount that will take (50% off of accPriceIncrement) if (accPriceIncrement is not = NULL) and a coupon code is entered.
If this isn't clear, please let me know.
Thanks in advance!
You would store the coupon code as a session variable so that you could refer to it in a calculation or discount rule based on the value of the accPriceIncrement column.
I know that, I have the code stored stored as a session variable, I just don't know how to do the calculation...
Attached is what I've tried so far, but it doesn't really make too much sense to me.
in the calcualtion, you are using the Based on items column value, this takes an Item ID as the first argument, it is intended for only one item in the cart,
you should be using the Based on items with a specific column value:
Total of 'Total price' where 'accTipPriceInc' has a value of '1' 'times' '0.5'
Ok, I think I'm getting closer....
Attached is a screenshot of what I've done.
The thing that doesn't make sense to me is where it says: if the total number of items where 'MyColumn' has a value of 'MyValue' is '>=' to a value of '0'. What I need is simply: if the total number of items where 'MyColumn' has a value that is '>=' to a value of '0'.
you have the trigger set correctly now, but not the calculation.
for the calculation, use Based on items with a specific value:
Total of 'TotalPrice' where 'MyColumn' has a value of '1' 'times' '0.5'
I think this is what you're asking me to do... (see attached)
It still doesn't calculate any discount. :-(
Please forgive me if I'm being thick headed, but I just want to make sure that you know "MyColumn" doesn't always have the same value. And I want the coupon to take 50% off of "MyColumn" if "MyColumn" doesn't equal "0".
OK, I had misunderstood then
the calculation should be:
Based on multiple of column subtotal
subtotal of column 'MyColumn' times '0.5' 'plus' '0'
if you are still having a problem with this, create a new php page, and add a new cart display manager to it.
on the second page of the display manager wizard, set it to display all columns.
send me a link to this page and an item i can use to test.
