UE4 only for PHP ?
Thread begun 3/25/2010 9:56 am by info145869 | Last modified 3/25/2010 6:53 pm by Dani Chankhour | 3460 views | 7 replies |
info145869
UE4 only for PHP ?
Does the new version only work with PHP and ASP models are not longer supported ?
Please advise
Dani Chankhour
That is correct, UE is PHP only.
info145869
Well if i can not run 3.07 and 4.0 side by side what am i doing with all my old and new ASP based websites ? Badly thought out. It supported both since version 1 and has been integrated since a couple years now.
Not acceptable
info145869
okay de-installed version 4 back to 3.07, now getting errors.
1st none of the old server behaviors are recognized anymore. Using insert universal email throws javascript errors.
DigitalFile pro is not defined.
Please advise
info145869
FYI WinFileCache.dat has been deleted
Dani Chankhour
there might be an issue with your configuration folder. try renaming your configuration folder, here is a link to instructions on this:
info145869
i don't think the pdf you linked to has anything in it regarding renaming, just deleting the WinFileCache.dat which i have done.
what happens if i rename the config folder? are not all extensions than disabled ?
Dani Chankhour
Sorry, here is another link:
146/
Yes. renaming your configuration folder will disabled your extension and you will need to reinstall the extensions. But i think the configuration folder got corrupted with and install of UE 4 and then the reinstall of UE 3.
