Sub Navigation Issues
Thread begun 3/24/2010 10:54 am by adam106173 | Last modified 3/26/2010 8:44 pm by Dani Chankhour | 3448 views | 5 replies |
adam106173
I have two questions regarding the sub menus on PowerStore 3. The first is the main horizontal bar does not show any secondary menus in IE 7 on XP, though it works on Firefox and every browser on the mac. For example, Products>Furniture> - On IE, nothing shows up past this.
Here is a link:new_site/
Second question is I can't find the .css to change the style of the accordian side menu. It's gotta be somewhere, right?
Dani Chankhour
In regard to your second question, the colors are being added dynamically. So to change the colors, open the Main.dwt.php file and you could see the colors being applied at line 165 and 166.
I will do some more testing for the IE 7 issue to see if i can reproduce the issue on my end.
adam106173
Thank you. I see where I was able to change the background color of the side menu. There is a blue border than goes around the open panel one the side menu which I'd like to change, plus I'd like to change the padding, or height of each button. I have a lot of choices and need to reduce the size some. I don't see those anywhere on the template page.
Dani Chankhour
That is placed in the spry_custom.css file in the css folder.
And you probably can make most of the changes under this class:
.AccordionPanelTab
adam106173
Perfect. Please let me know about your test results on IE 7.
Thank you.
Dani Chankhour
It looks like the css have changed so it is hard for me to debug the issue.
I have opened a support ticket to further assist you with this issue:
