Repeat selection works on one page, not on another
Thread begun 3/24/2010 10:33 am by jeffmg279672 | Last modified 3/25/2010 2:50 pm by Dani Chankhour | 1995 views | 3 replies |
jeffmg279672
I have two pages which are broadly similar - each pulls listings from its own database table and displays them as 152px square images. On each I've set up a repeat region pulling all records, and then applied the DA repeat selection server behavior, using 5 as the number of repeats. So, in theory I should have 5 images in the first row, repeated however many times as necessary till all records are pulled.
In the artists.php page this works fine, but in sportsman.php I get a long line of images. I've tried deleting both the repeat region and repeat selection behaviors in case I'd gone wrong somewhere, but it doesn't make any difference. I've even printed out the code for the two tables and compared them line by line and apart from one having a "show region if recordset not empty" behavior on it, they appear to be identical. So - why does one work and the other doesn't?
I've attached the two pages as a zip file - they can be seen online at:
artists.php &
sportsman.php
Dani Chankhour
In your sportsman.php file you need to apply the repeat region to the table instead of the column, so you can just move line 96 to above the <table> tag and move line 119 to under the </table> tag.
jeffmg279672
Thanks Dani, that seems to have fixed it. I have another problem which I hope you can give me a steer on. sportsman.php pulls all available records from a db table "sportsman", and when you click on one it should select any listings for that individual and display them on the next page (sportsmanResults.php) - so if there were two listings with the same ID (ie two for David Beckham) it would show both of these as a thumbnail image. You then click on whichever you want to view and it gives more detail on the final page - sportsmanDetails.php - pulled from the db table "sporting".
What's happening though is that although there are 15 listings in "sportsman" and 3 in "sporting", the results page shows all 3 listings from "sporting" rather than whichever one matches the ID assigned to the sportsman.
I've no idea why this isn't working - again, the live site will show what's happening, but I've attached the 3 pages as a zip file.
Dani Chankhour
The problem is on your results page. you need to update the rsSportsResults record set to filter based on sportsmanID. That should give you the result you are looking for.
