what if i have another solution pack installed
Thread began 3/24/2010 9:53 am by edrosenthal350859 | Last modified 3/24/2010 10:22 am by Jimmy Wu | 888 views | 1 replies |
edrosenthal350859
i want to be able to use the registration pack but first want to know if
i already have say, a solution pack that contains the wa_globals.php file, such as
the powercms package installed say in a directory mydomain.com/powercms/
Will i install the registration pack in a different directory such as
mydomain.com/userreg/
and expect that globals contained will not interfere with variables that are mentioned
in another pack?
Example conflict might be that these session variables while running don't interfere with each other?
simple question but just wanted to ask anyway...
Jimmy Wu
If the two are installed in different directories, they will not interfere with each other. In fact, if you have 2 of the same solution pack installed on different directories, they will not interfere with each other.
