HTML Editor w/ADDT - Any solutions or instructions?
Thread begun 3/23/2010 1:41 pm by tlshoaff392246 | Last modified 4/14/2010 4:51 pm by jerry348919 | 3984 views | 7 replies |
tlshoaff392246
Greetings,
I've seen posts concerning this but haven't seen a solution.
Has anybody had any luck getting the HTML editor to work properly with an ADDT form? If so, would you please share? Every time I an the HTML editor and select "update" it deletes my entry in the database.
Thanks...
Jimmy Wu
This most likely has to do with the ADDT form having dynamically named fields that doesn't get the same name when HTML Editor is applied. What is the code for the form before and after HTML editor is applied?
tlshoaff392246
Code: Before and After
BEFORE:
<tr>
<td class="KT_th"><label for="cContent_<?php echo $cnt1; ?>">Content:</label></td>
<td><textarea name="cContent_<?php echo $cnt1; ?>" cols="100" rows="20" id="cContent_<?php echo $cnt1; ?>"><?php echo KT_escapeAttribute($row_rstbl_content['cContent']); ?></textarea>
<?php echo $tNGs->displayFieldHint("cContent");?> <?php echo $tNGs->displayFieldError("tbl_content", "cContent", $cnt1); ?> </td>
</tr>
AFTER:
<tr>
<td><?php
// WebAssist iRite: Rich Text Editor for Dreamweaver
$WARichTextEditor_1 = CreateRichTextEditor ("cContent_php_echo_cnt1_", "../HTMLEditor/", "100%", "600px", "Default", "../custom/content_release3_cContent_php_echo_cnt1_1.js", "".KT_escapeAttribute($row_rstbl_content['cContent']) ."");
</tr>
Any ideas???
Maybe try:
<tr>
<td><?php
$WARichTextEditor_1 = CreateRichTextEditor ("cContent_" . $cnt1. "", "../HTMLEditor/", "100%", "600px", "Default", "../custom/content_release3_cContent_php_echo_cnt1_1.js", "".($row_rstbl_content['cContent']) ."");
</tr>
tlshoaff392246
Success....
Ray,
Thank you sooo much! By simply removing the "KT_escapeAttribute" from the code made all of the difference. Now I can proceed. I really appreciate it.
Torrey
jerry348919
HTML Editor and ADDT
I just downloaded the new HTML Editor and am having the following issue:
I create the Dynamic Form using Dynamic Form Wizard in ADDT
(All works as it should when tested)
When I add HTML Editor to the field I wish to enable HTML Editor on, it makes the necessary changes to the file, when tested, All looks as if it us going to work, however when I hit the update or insert record, it completely removes all the text from that field in the database.
I have read the above post regarding how to resolve the issue... (remove KT_escapeAttribute) however it does not resolve the problem of not updating or inserting new record as required.
Any information or assistance would be greatly appreciated.
can you send a copy of your page please so that I can examine the code?
jerry348919
Figured it out
Sorry for the delay, was under the weather the last couple of days. I figured out by having to go into the insert and update fields and re-linking the text field. Somehow I felt that this should have been done automatically in HTML Editor as the old version handled this quite nicely.
