Adding Custom Code to Form
Thread begun 3/23/2010 9:19 am by A Sound Design | Last modified 3/23/2010 10:56 am by Jimmy Wu | 1322 views | 1 replies |
A Sound Design
I would like to add some custom code to a form created using CSS Form Builder. What I need to do is cut and paste some HTML code from another web site so that it displays in the form. It is for a Reservation Calendar and shows the availability of the rental property and so needs to go next to the section for adding arrival and departure dates.
Jimmy Wu
You would just have to copy and paste this code into the correct place after the form is generated. The code may be written over if you edit the form again, so if you edit the form using Form Builder, you would want to paste the code back in again. Having an extra field in the form will not cause any issues.
