Java script error after activation screen
Thread begun 3/23/2010 9:14 am by dennisocasio116615 | Last modified 3/24/2010 3:09 pm by Eric Mittman | 2052 views | 3 replies |
dennisocasio116615
Dreamweaver CS4 keeps locking on me right after activation of EMS 3.0.
I get the following message...
While executing onLoad in wacs_quickinsert.htm, the following JavaScript error(s) occured:
At line 145 of file "Sol MeliĆ” VC HD:Applications:Adobe Dreamweaver CS4:Configuration:Commands/:wacs_quickinsert.js": hasAutoSave is not defined
Have you tried deleting your cache file with the steps listed in this document?
Please give this a try, if you continue to have problems there might be an issue with your configuration folder. If this is the case you should be able to get past the issue by renaming your configuration folder, here is a link to instructions on this:
showpost.php?p=12293&postcount=2
Please post back and let us know if you continue to have problems with this.
sales377016
I'm having similar problem
Just installed sculptor 3 and has crashed on me 5 times so far today, now I'm getting this error when I click on the customize css button
while executing onload in wacs_wizard.htm, a javascript error occured
when I click ok twice the screen just freezes
Any solutions?
Have you tried the solutions suggested in the previous post? The info listed there should help you get past this error.
