Admin settings won't save
Thread begun 3/22/2010 6:20 pm by downloads336743 | Last modified 3/29/2010 8:03 am by Ray Borduin | 3804 views | 6 replies |
downloads336743
Hi there,
I have a problem with saving the settings on the admin page. The page doesn't go anywhere when "save changes" is clicked and the database is not updated.
Can anyone suggest a resolution?
Nic
Jimmy Wu
Make sure that the connection file for the database still has the correct information. Do you get any errors when you're saving the settings?
downloads336743
Hi Jimmy,
No in fact it does nothing - no movement away from the page at all and no errors. I am assuming it might be a missed file (JS / AJAX) during the upload process but have no idea what file could have been missed or uploaded incorrectly. I tired reuploading the JS folder but it didn't work.
Any ideas?
Many thanks
Nic
downloads336743
****BUMP***
Hi, i reinstalled the whole software and put it on a brand new database and it's still not doing anything when clicked - the text input box turns green but when i click save it goes nowhere and makes no updates....Any ideas? Anyone else having the same problem?
Jimmy Wu
I am opening a backend ticket so I can take a look at this issue in more detail with you. To check your backend ticket, log in to your account at www.webassist.com and check your support history.
Neilious
Hi I had exactly this issue when I installed Powerstore, everytime I made a change to the Admin settings and clicked save nothing happened. In the end I fixed it by completing the 'state' field under 'map and directions'. As I'm in the UK I didn't fill it in originally, but on the off chance I tried it with UK in there and I was able to save settings from then on. Sounds strange I know, but it worked. Hope this helps
Neil
That is a good point, it could be a validation issue with another field causing it not to update. Click through all of the tabs to see if there are any errors associated with the fields you are updating if they don't appear to be properly saved.
