Formatting mySQL Dates with Multiple Insert
Thread began 3/22/2010 10:25 am by Ian | Last modified 3/22/2010 4:52 pm by Ian | 1525 views | 5 replies |
Ian
I need to be able to format a date Y-m-d with the multiple insert behaviour.
I can do this with the Insert Record behaviour no problem at all, but struggling with the multiple insert.
How can I adopt the StrtoTime function with a repeated text field with the multiple insert behaviour?
I've tried the below code but this doesnt seem to work.
date('Y-m-d',strtotime(WA_AB_getLoopedFieldValue("invdate", $WA_multipleUpdateCounter)
Thanks in advance,
Best Regards,
Ian
Ian
Hi WA,
Would appreciate a reply on this today if possible. Its 20:44 here in the U.K. and I need to get this working for the morning as part of a support call.
Thanks,
Ian
I was able to get the date conversion working on a multiple update page where I had two fields, "date" and "name" by changing the following line of code:
$WA_fieldValuesStr = "".WA_AB_getLoopedFieldValue("textfield", $WA_multipleInsertCounter)  ."" . "|" . "".WA_AB_getLoopedFieldValue("textfield2", $WA_multipleInsertCounter)  ."";
$WA_fieldValuesStr = "".date("Y-m-d", strtotime(WA_AB_getLoopedFieldValue("date", $WA_multipleInsertCounter)))  ."" . "|" . "".WA_AB_getLoopedFieldValue("name", $WA_multipleInsertCounter)  ."";
Ian
Thank you Jason, I will take another look at it.
Ian
Ian
Hi Jason,
OK, I've given this a go and no matter if I put the date in to the text field as 23/03/2010 or 2010-03-23 it enters the value of 1970-01-01 into the database.
This is the line of code:
$WA_fieldValuesStr = "".WA_AB_getLoopedFieldValue("select", $WA_multipleUpdateCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("invref", $WA_multipleUpdateCounter) ."" . "|" . "".date("Y-m-d", strtotime(WA_AB_getLoopedFieldValue("invdate", $WA_multipleInsertCounter))) ."" . "|" . "".WA_AB_getLoopedFieldValue("intref", $WA_multipleUpdateCounter) ."";
Have I missed something?
Cheers
Ian
Ian
Hi Jason,
Sussed it.
Not sure why it works this way, but I've added a JQuery date picker and assigned it to the text field. And now it saves. Not sure why this works but a manual input doesn't but hey ho!
Thanks for your help at such short notice.
Best Regards,
Ian
