DataAssist Multiple Record Update not updating records
Thread begun 3/22/2010 8:21 am by kevin347925 | Last modified 3/23/2010 10:52 am by Jason Byrnes | 5112 views | 9 replies |
kevin347925
Hello,
I have spent a lot of time trying to get the multiple record update behavior to work, and I have not been successful. From other forum posts, I know that there is a bug, but I am unable to fix it in my code. Is the DataAssist version update coming soon? The code is pasted below. Help would be very much appreciated.
// WA DataAssist Multiple Updates
if (isset($_POST["updateshow"])) // Trigger
$WA_loopedIDField = array("WADA_RepeatID_DataID");
$WA_connection = $conn_dynamic;
$WA_table = "DynamicData";
$WA_redirectURL = "MANAGEslideshow.php";
$WA_keepQueryString = false;
$WA_indexField = "DataID";
$WA_fieldNamesStr = "MakeSlide|SlideTitle|HideSlide|ButtonLabel|ButtonOrder";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_connectionDB = $database_conn_dynamic;
$WA_multipleUpdateCounter = 0;
while (WA_AB_checkLoopedFieldsNotBlank($WA_loopedIDField, $WA_multipleUpdateCounter)) {
$WA_fieldValuesStr = "".WA_AB_getLoopedFieldValue("removeslide", $WA_multipleUpdateCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("slidetitle", $WA_multipleUpdateCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("showslide", $WA_multipleUpdateCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("buttontitle", $WA_multipleUpdateCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("slideorder", $WA_multipleUpdateCounter) ."";
$WA_where_fieldValuesStr = WA_AB_getLoopedFieldValue($WA_loopedIDField[0], $WA_multipleUpdateCounter);
$WA_where_columnTypesStr = "none,none,NULL";
$WA_where_comparisonStr = "=";
$WA_where_fieldNames = explode("|", $WA_indexField);
$WA_where_fieldValues = explode("|", $WA_where_fieldValuesStr);
$WA_where_columns = explode("|", $WA_where_columnTypesStr);
$WA_where_comparisons = explode("|", $WA_where_comparisonStr);
$updateParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WhereObj = WA_AB_generateWhereClause($WA_where_fieldNames, $WA_where_columns, $WA_where_fieldValues, $WA_where_comparisons );
$WA_Sql = "UPDATE `" . $WA_table . "` SET " . $updateParamsObj->WA_setValues . " WHERE " . $WhereObj->sqlWhereClause . "";
$WA_multipleUpdateCounter++;
if ($WA_redirectURL != "") {
?><?php
// RepeatSelectionCounter_1 Initialization
$RepeatSelectionCounter_1 = 0;
$RepeatSelectionCounterBasedLooping_1 = false;
$RepeatSelectionCounter_1_Iterations = "1";
?><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 TRANSITIONAL//EN">
<html>........
<form name="form1" method="post" action="">
// RepeatSelectionCounter_1 Begin Loop
$RepeatSelectionCounter_1_IterationsRemaining = $RepeatSelectionCounter_1_Iterations;
while($RepeatSelectionCounter_1_IterationsRemaining--){
if($RepeatSelectionCounterBasedLooping_1 || $row_rs_slideshow){
<table class="tableinfo" width="100%" border="0" cellspacing="0" cellpadding="0">
<tr>
<th>Slide Order:</th>
<th>Slide Title:</th>
<th>Button Title:</th>
<th>Category<br />(optional):</th>
<th>&nbsp;</th>
<th>Show<br />Slide:</th>
<th>Remove<br />Slide:</th>
</tr>
<?php do { ?>
<tr>
<td style="border-left:#46290D 1px dotted; width:50px;"><label><input type="hidden" name="WADA_RepeatID_DataID_<?php echo $RepeatSelectionCounter_1; ?>" id="WADA_RepeatID_DataID_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_rs_slideshow["DataID"]; ?>" />
<input class="slideinput" type="text" name="slideorder_<?php echo $RepeatSelectionCounter_1; ?>" id="slideorder_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_rs_slideshow['ButtonOrder']; ?>"></label></td>
<td><label><input class="slideinput" type="text" name="slidetitle_<?php echo $RepeatSelectionCounter_1; ?>" id="slidetitle_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_rs_slideshow['SlideTitle']; ?>"></label></td>
<td><label><input class="slideinput" type="text" name="buttontitle_<?php echo $RepeatSelectionCounter_1; ?>" id="buttontitle_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_rs_slideshow['ButtonLabel']; ?>"></label></td>
<td style="vertical-align:middle; text-align:center; width:50px;"><a href="DYNAMICresults.php?cat=<?php echo $row_rs_slideshow['Category']; ?>" target="_blank"><?php echo $row_rs_slideshow['Category']; ?></a></td><td style="padding:10px;"><label><a href="DYNAMICdetail.php?DataID=<?php echo $row_rs_slideshow['DataID']; ?>">edit</a></label></td>
<td><input <?php if (!(strcmp($row_rs_slideshow['HideSlide'],"show"))) {echo "checked=\"checked\"";} ?> type="checkbox" name="showslide_<?php echo $RepeatSelectionCounter_1; ?>" id="showslide_<?php echo $RepeatSelectionCounter_1; ?>" value="show"></td>
<td><label><input type="checkbox" name="removeslide_<?php echo $RepeatSelectionCounter_1; ?>" id="removeslide_<?php echo $RepeatSelectionCounter_1; ?>" value=""></label></td>
</tr>
<?php } while ($row_rs_slideshow = mysql_fetch_assoc($rs_slideshow)); ?>
<tr>
<td style="border-left:#46290D 1px dotted; padding:20px 50px;" colspan="7">
<div align="center">
<input class="button" style="font-family:Arial;" type="submit" name="updateshow_<?php echo $RepeatSelectionCounter_1; ?>" id="updateshow_<?php echo $RepeatSelectionCounter_1; ?>" value="Update Slides">
</div></td>
</tr>
</table>
} // RepeatSelectionCounter_1 Begin Alternate Content
else{
<td>No records match your request.</td>
<?php } // RepeatSelectionCounter_1 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_1 && $RepeatSelectionCounter_1_IterationsRemaining != 0){
if(!$row_rs_slideshow && $RepeatSelectionCounter_1_Iterations == -1){$RepeatSelectionCounter_1_IterationsRemaining = 0;}
$row_rs_slideshow = mysql_fetch_assoc($rs_slideshow);
$RepeatSelectionCounter_1++;
} // RepeatSelectionCounter_1 End Loop
</form>
Thank you in advance.
Peace,
Kevin
try changing the following line of code:
<?php $RepeatSelectionCounter_1++; ?><?php } while ($row_rs_slideshow = mysql_fetch_assoc($rs_slideshow)); ?>
kevin347925
No luck.
Hi Jason,
Thanks for the help.
I tried the line of code you gave me, and I didn't have any luck. The unchanged data displays in the fields after I hit submit.
If you reload the page does the changed data display?
It may be that the rs_slideshow recordset is on the page before the update behavior. if this is the case, the recordset is created before the data in the database is updated. This will cause the recordset to be created with the old data. you may have to manually move the recordset code so that it is after the update behavior.
kevin347925
still no luck
Jason,
The data does not change after reloading the page.
I moved the recordset and still no luck. The data does not change after I submit the page.
please send a copy of the actual php page in a zip archive so I can see the code in context.
kevin347925
Sure thing.
The submit button is part of the repeat selection, so its name has been changed to be dynamic.
change:
<input class="button" style="font-family:Arial;" type="submit" name="updateshow" id="updateshow" value="Update Slides">
kevin347925
After making the change you requested, I submitted the form. However, it actually cleared the database column that I had tried to change.
In short, when I hit submit, rather than updating the column of fields, it erased all the data in a column.
I have created a support ticket for you so we can look into this in more depth.
to view and edit your support ticket, please visit your support history:
forums/
