Incrementing Unit Sales Number
Thread begun 3/21/2010 1:10 pm by msjj000 | Last modified 3/25/2010 12:28 pm by Jimmy Wu | 2606 views | 3 replies |
msjj000Beta Tester
Hi WA,
I know I can change the starting sale # by accessing it via the Database admin.
is there a way to set the starting invoice number or at least the incrementing it?
Thanks, Mark.
Jimmy Wu
I'm not sure what you're getting at with the invoice number. Do you mean the order number?
What is the purpose for increasing the invoice/order number for a certain sale?
msjj000Beta Tester
Hi Jimmy,
Rather thanthe order number starting at 1, then 2 then 3 etc can you have the first order increment so that the first order is 1 then the second sale/order number 11 the third 21 and the fourth 31?
Mark.
Jimmy Wu
The order id is an autoincremented field in the database, so it will increment the id automatically. You can set the autoincrement increment amount for the database like this:
replication-options-master.html#sysvar_auto_increment_increment
You would need to make the call:
SET @@auto_increment_increment=10;
This will change the auto_increment_increment for all tables though, so other tables that have auto_increment set on a column will also increment by 10.
