CSS files are missing
Thread begun 3/21/2010 8:13 am by sagawebsites383115 | Last modified 3/22/2010 10:50 am by Jimmy Wu | 1652 views | 2 replies |
sagawebsites383115
In PowerStore3 the following files are referred to in the head of Products_Search.php:
WA_DataAssist/styles/Refined_Slate.css
WA_DataAssist/styles/Arial.css
The following files are reffered to in the head of users_LogIn.php:
WA_SecurityAssist/styles/Refined_Pacifica.css
WA_SecurityAssist/styles/Arial.css
These files do not exist. Is it safe to delete these lines?
i.edwards384429
update
Hi
I would think you could delete the lines, not sure what you would gain.
If you are not totaly happy with CSS and paths I would suggest leave well alone.
The guys at WA often use devious methods to acheive an end so if it works...
cheers
Ian
Jimmy Wu
It should be safe to remove those lines, since the css that is being referenced does not exist at those paths.
