Changing "product list" text to category name
Thread begun 3/21/2010 4:52 am by rmcadams351257 | Last modified 3/25/2010 4:42 pm by Eric Mittman | 4119 views | 6 replies |
rmcadams351257
Hi
I would like to have the category name show up at the top of the page insted of the words "product list".
I have seen how to do this with power store 2, changing Product List<br /> to
<?php if ($totalRows_categories > 0) { // Show if recordset not empty ?><?php echo $row_categories['CategoryName']; ?><br/>
<?php }else{ ?>Product List<br />
<?php } ?>
and making a recordset on the product results page.
But when I try that with Power store 3 it will not work. :(
can anyone help with this ?
Ron
Jon CunninghamBeta Tester
Same Problem
Hi, I have followed the procedure found under thread showthread.php?t=3699 and I am unable to get this working with Powerstore 3.
Please can anyone shed some light in this.
Kind regards
Jonathon
This is not a supported feature of PowerStore 3 but if you alter the products query slightly you can get it to display the category of the first item in the recordset by making these changes.
1) on line 84 of Products_Results.php update the code from this:
$WADbSearch1->whereClause .= "ProductID
to this
$WADbSearch1->whereClause .= "ps3_products.ProductID
2) on line 136 update the query to look like this:
$query_WADAProducts = "SELECT * , coalesce((select ps3_productoptions.GroupingID from ps3_productoptions WHERE ps3_productoptions.ProductID = ps3_products.ProductID limit 1),ps3_products.ProductID) AS GroupingID FROM ps3_products JOIN ps3_productcategories ON ps3_products.ProductID = ps3_productcategories.ProductID JOIN ps3_categories ON ps3_productcategories.CategoryID = ps3_categories.CategoryID WHERE ProductLive = 1 GROUP BY GroupingID ORDER BY ProductName";
3) you can then display the category name with this php code near line 426
<?php echo $row_WADAProducts["CategoryName"]; ?>
Keep in mind though that this will only display the category for the first item in the recordset, and this will only display if there are items returned from the recordset. So if you do a search for a particular category it will work just fine, but if you view the results without any filtering then then you will see the category for the first item in the list.
It might be a better idea to make these changes then display the category name inside of the item display next to it's name.
rmcadams351257
Not sure?
Thanks Eric
I think I understand what you mean by "will only display the category for the first item in the recordset"......Well maybe I don't.
What I was trying to do was, if you clicked let's say Shoes in the left menu then the products results page whould display Shoe at the top of the page somewhere. This maybe what you're trying to explane to me, but I'm not sure. I know this is a short coming on my part. You have helped me before and did a grate job. Is there a way to have the category show up at the top of the products results page. It is fairly straight forward in Power store 2. So I thought it whould be close to the same in Power store3.
Again please excuse me for being a newbe PHP,Databases & the like.
Ron
If you make the changes to your pages and click on the shoes from the left menu you would see shoes at the top of the listing.
What I really meant by saying it will only display the category for the first item is that if you do a search or view all of the items and there are more than one category of item listed it will display the category for the first item, if any of the other items belong to a different category this could be confusing.
The only way that I could think of to get around this would be to do a check of the categories in the recordset by looping over them and seeing if any of them differ. If they are all the same then display the category, or else display an alternate message.
rmcadams351257
I got it now
Hi: Eric
That answered my question. (very good explation) I now see what you where saying.
Your the best. I will try that and see if with my products it gets to confusing. A lot of them are closely related so it might not be to bad. If it is i'll just change it back. You guys at WebAssist always seem to come through. :)
Ron
P.S. maybe something like this in Powerstore3 update or Powerstore4
I think this is an excellent feature request, I have logged it for PowerStore.
