Trouble combining Data Assist Insert Record & Digital File Pro
Thread begun 3/20/2010 9:00 am by mattoconnell298972 | Last modified 3/21/2010 7:56 am by mattoconnell298972 | 3221 views | 4 replies |
mattoconnell298972
I am having trouble combining these two functionalities.
I can use Data Assist Insert Record to upload text to my database no worries.
I can upload files to my server using DFP no worries.
If I have both on the same page and want to send the filename to a field in my database the image doesn't upload and the filename isn't sent to the database.
I have seen the forum posts and tutorial where it says to get the Server Filename variable for Data Assist - but which ever variable I select, none seem to work.
Is there a trick to this??
This is the code:
Thanks for any help in advance.
<?php require_once('../../Connections/connTest.php'); ?>
<?php require_once("../../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once("../../WA_DigitalFilePro/HelperPHP.php"); ?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../images/user/thumbs/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "1",
'ResizeWidth' => "85",
'ResizeHeight' => "85",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if($_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_UploadFiles("WA_UploadResult1", "thumbUpload", "0", "", "JPG:80", $WA_UploadResult1_Params);
require_once( "../WA_SecurityAssist/Helper_PHP.php" ); ?>
<?php require_once( "../WA_Globals/WA_Globals.php" ); ?>
<?php require_once( "../WA_CMS/WA_CMS.php" ); ?>
<?php require_once('../Connections/localhost.php'); ?>
<?php require_once("../../HTMLEditor/WARichEditorPHP.php"); ?>
// WA Application Builder Insert
if ($_SERVER["REQUEST_METHOD"] == "POST") // Trigger
$WA_connection = $connTest;
$WA_table = "content";
$WA_sessionName = "contentID";
$WA_redirectURL = "newsDetail.php";
$WA_keepQueryString = false;
$WA_indexField = "contentID";
$WA_fieldNamesStr = "contentTitle|thumbImg|contentHome|contentLong|contentShort|date";
$WA_fieldValuesStr = "".((isset($_POST["contentTitle"]))?$_POST["contentTitle"]:"") ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."" . "|" . "".((isset($_POST["contentHome"]))?$_POST["contentHome"]:"") ."" . "|" . "".((isset($_POST["contentLong"]))?$_POST["contentLong"]:"") ."" . "|" . "".((isset($_POST["contentShort"]))?$_POST["contentShort"]:"") ."" . "|" . "".((isset($_POST["contentDate"]))?$_POST["contentDate"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_connectionDB = $database_connPriefert;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
CraigRBeta Tester
i notice that the default file path is empty.
take a look at this post which may help...
showthread.php?t=9239
mattoconnell298972
No Luck
Hi Craig,
Thanks for the reply....I tried adding a default filename but still no luck.
The problem is, if I try any of these things separately, like just uploading a file - I have no problems.
If I have a text input field and I want to insert a daatbase record - also no problems.
But if I want to upload a file and send the filename to the database, that's when it doesn't work.
No file uploads and no record in the db.
Not sure what the problem is??
CraigRBeta Tester
here is a troubleshhoting tip...
on the insert page, change line...
$WA_redirectURL = "tblsuccess_results.php";
$WA_redirectURL = "";
so that the page will not redirect.
then go the the bindings panel and expand the WA Digital File pro Global Status group, add the debug info binding to the page.
Please post back the debug info results after trying to upload a file.
this should indicate what is going wrong, and maybe someone can help a bit further
regards
mattoconnell298972
Crisis Over
Thanks for the help Craig, I had an incorrect redirect!! Working OK now.
