Upgrading old User Reg system to WA version
Thread begun 3/19/2010 7:11 pm by zanimul379168 | Last modified 3/22/2010 10:10 am by Jason Byrnes | 1395 views | 1 replies |
zanimul379168
I managed to get the data from a .asp MS Access driven user registration system ported over to the WA User Reg pack. At first I thought I had it nailed, until one user tried to login and he had used a password that did not fit the Spry requirements. So, I'm not sure what options I have at this point - reset all users passwords to a compliant one and inform them of the change? Or is there a better way?
TIA!
you can change the spry validation requirements by editing the following code on the login page:
var sprypassword1 = new Spry.Widget.ValidationPassword("sprypassword1", {minChars:6, minAlphaChars:1, minNumbers:1, validateOn:["blur"]});
minChars:6 - setts the minimum passsword length to 6 characters
minAlphaChars:1 - sets the password to require at least one letter
minNumbers:1 - sets the password to require at least one number
you can change these settings to fit the existing passwords.
You will also need to adjust the server validation settings.
This line setts the minimum length to 6
$WAFV_Errors .= WAValidateEL(((isset($_POST["userpassword"]))?$_POST["userpassword"]:"") . "",6,50,true,2);
this line requires at list one number:
$WAFV_Errors .= WAValidateRX(((isset($_POST["userpassword"]))?$_POST["userpassword"]:"") . "","/[0-9]/",true,3);
this line requires at least one letter:
$WAFV_Errors .= WAValidateRX(((isset($_POST["userpassword"]))?$_POST["userpassword"]:"") . "","/[a-z,A-Z]/",true,4);
