PowerStore 2 & Signature Card Services
Thread begun 3/19/2010 5:17 pm by toby379423 | Last modified 3/23/2010 3:21 pm by Jimmy Wu | 4061 views | 5 replies |
toby379423
Hi there,
I'm trying to set up my PowerStore (store/) and was wondering of anyone has set up a store with Signature Card Services. Apparently they have an Authorize.net emulation where you all you need to do is add this url (order.pl) and then the account number. I know that normally in the WA_Globals File you would change the settings here:
//Authorize.net Settings
$WAGLOBAL_Authnet_Sandbox = "TRUE"; //Set to true if you wish to use the Authorize.net Sandbox for testing transactions.
$WAGLOBAL_Authnet_login = "";
$WAGLOBAL_Authnet_tran_key = "";
But what I'm not sure about is, what would I put for the "login" & "tran_key"? I called Signature but they were already closed so I figured I'd try here to see if I could find a solution.
Thx!
Jimmy Wu
I'm not sure how the Signature card services works, since its not a supported gateway, so your best bet is to wait for their response on this. If you're going to use an emulator, why not just go directly with Authorize.net?
toby379423
Yeah I know I'd like to go with Authorize.net but that's who the client chose & isn't going to change it...
So I added the information to the WA_Globals file in the Authorize.net part:
/* Payment Settings
* Use this key to determine the appropriate value for the $WAGLOBAL_Gateway setting:
* PayPal = 1
* Authorize.net = 2
$WAGLOBAL_Gateway = 2; //Enter the appropriate value based on the above key. PayPal is specified by default.
$WAGLOBAL_Test_Mode = false; //Set to true if you are testing your shopping cart and do not want to send information to your payment gateway.
//Only complete the payment gateway options for the gateway you have selected to use in the $WAGLOBAL_Gateway setting.
$WAGLOBAL_Authnet_Sandbox = "false"; //Set to true if you wish to use the Authorize.net Sandbox for testing transactions.
$WAGLOBAL_Authnet_login = "XXXXXXX";
$WAGLOBAL_Authnet_tran_key = "XXXXXXXXXXXXXXX";
Did a test order & got this:
Transaction Not Completed
We're sorry
Your transaction could not be completed. Either your credit card information or billing address has problems and cannot be processed
Please return to checkout and try again.
Paypal Full Response :
USPS Full Request :
USPS Full Response :
Any ideas why?
Jimmy Wu
Well, part of the problem could be that the emulator doesn't work exactly like Authorize.net works. To take a look at this, you would want to print out the Authorize.net request and response:
<br />The Authorize.net full requst is: <?php echo(AuthNet_Result("Full Request")) ?><br />
<br />
The Authorize.net full response is: <?php echo(AuthNet_Result("Full Response")) ?><br />
toby379423
I contacted Signature and they pointed out the problem. Thanks for the help!
Jimmy Wu
That's good to hear. If you wouldn't mind, could you post up the resolution to the issue so other users that might be using the same payment gateway can benefit from the resolution as well?
