CSS Menu Writer 2.03 Initializing
Thread begun 3/19/2010 1:13 pm by junior294776 | Last modified 3/19/2010 2:49 pm by Jason Byrnes | 2553 views | 5 replies |
junior294776
I'm having the same problem here my CSS menu writer stops on initializing and does nothing...
I Already deleted my configuration folder, unistalled all my extensions and installed CSS MW again but the problem still.
I need this working fast...
try deleting the Dreamweaver cache file from the users configuration folder:
junior294776
Problem Still
As I told before already did this and already deleted the configuration folder and installed the extension again...
you mention that you have deleted the configuration folder only, then reinstalled the extension.
My suggestion was to delete a single file from the configuration folder _after_ installing the extension.
if you still have a problem after deleting the Dreamweaver cache file, please provide some additional details on your set up:
What Is you OS?
What version of Dreamweaver?
Have you defined a site in Dreamweaver?
Have you created a new htm or PHP file and saved it to that site?
is this new file open when you launch Menu Writer?
can you provide details on how the site is defined, such as local folder?
junior294776
CSS Problem Still
OS
Windows Vista 32
Dreamweaver CS3
Site Defined
YES
Created File
YES
The file is open
YES
local root folder:
C:\inetpub\wwwroot\bbggranite\
Steps:
1º Unistall the Extension thru adobe Extendion manager
2º reboot computer
3º Intall extension 2.03 thru adpbe Extension manager
4º rebot computer
5º Open Dreamweaver
6º insert - webassist - CSS Menuwriter...
7º Insert product Key
8º Leave all the options the way it is and press ok
Webassist Site Tools
Menuwriter
Initializing
Running time 00:00
This is happening with two of my computers, the only difference between the computers is one is a WINDOWS 7 64
I was reading the forum and lots of peoples are having the same problem
I have created a support ticket so we can look into the problem further. to view and edit your support ticket, please log into your support history:
forums/
