Submission form not sending photos
Thread begun 3/19/2010 10:20 am by mrobben375515 | Last modified 3/30/2010 6:45 am by Jason Byrnes | 5533 views | 17 replies |
mrobben375515
I just spoke with Jason Barnes a couple weeks ago about a few issues we had on support tickets... We got the submission form to work, but now it's not working again. I check the line of code that he changed ($WAFV_Errors .= WAValidateRQ((isset($_FILES["Registration_group_Upload_Pet_Photo"])?$_FILES["Registration_group_Upload_Pet_Photo"]:"") . "",true,6);) and the "FILES" is still there just as he put it. When I hit the submit button, the photo file isn't sent to the database...
please send a copy of your page so I can take a look at the code.
mrobben375515
it's index.php... I've gotten it to work but when others have tested it on other computers and browsers we haven't had success. It's also displaying an error at the very bottom of the page because some of the php code is outside of the html tags. I don't know how it got there, or where to place it. Thanks for your help...
neilo
Are you using a recordset called Pet_Reg on your page?
If so, the php code that finishes your page (after the closing </html> tag) would be:
mysql_free_result($Pet_Reg);
Are you still using a recordset called Pet_Reg (it will show in your Server Behaviors Panel), and what do the last few lines of your page code look like?
mrobben375515
there isn't a Pet_Reg in server behaviors, but there is a pgl_gallery_images recordset in the bindings...so I deleted the Pet_Reg part but the page is even more messed up now. When I hit submit it processes it for a little while and then goes to a blank screen. Here's the code for the last few lines of the page before i deleted the pet_reg part...
</body>
</html>
mysql_free_result($pg1_gallery_images);
and then after I deleted it...
</body>
</html>
neilo
Hiya,
I think you should zip and upload the page as Jason suggested originally before I butted in!
mrobben375515
sorry bout that...here it is
for the error message, delete the code at 897:
you do not have a recordset named "Pet_Reg" on the page, thus the error is occurring trying to destroy it.
If the image upload is working for some, but not for others there are a few possibilities:
a) On slower connections, submitting the image may exceed the php max_execution_time setting
b) uploading larger files may exceed the post_max_size setting
see the following page for information on PHP.ini settings that can effect upload:
config.php
neilo
Hi there,
Hopefully Jason will check out your page more thoroughly, but it seems that there is redundant code on your page, left over perhaps from previous forms and validations that are no longer part of your page's functionality.
There are three blocks of WA Server Validations server behaviors on your page (and listed in your Sever Behaviours panel) - the first two blocks (SimpleRegistration_submit and PetReg_submit) no longer seem to relate to a current form.
I would wait for Jason to cast an eye over things, but in the meantime if you wanted to, you could back up your page, and try removing the first two blocks of validations from the server behaviors panel and again remove the 'mysql_free_result($Pet_Reg);' line from the end of your page, as before.
neilo
Sorry Jason,
Didn't see you had posted!
