eCart 5 Javascript error
Thread begun 3/19/2010 9:38 am by admin18255 | Last modified 3/22/2010 9:34 am by Jason Byrnes | 1245 views | 1 replies |
admin18255
I am get the following error when using the checkout wizard:
While executing onLoad in WA Ecart
CheckoutWizard.htm, a JavaScript error occurred.
I am using eCart 5
CS3
OSX Snow Leopard
I also have tried deleting the cache file
Sean
In your order history, I see that you had purchased eCart 4 as well, did you have eCart 4 installed before installing eCart 5.
If so, did you remove eCart 4 from the extension manager first, or did you install eCart 5 over eCart 4?
If you installed eCart 5 over eCart 4, your configuration folder is most likely corrupted, follow step 2 at the following link:
146/
