Any way to forego e-mail verification step
Thread begun 3/18/2010 9:41 am by kelleypb318499 | Last modified 3/23/2010 1:39 pm by Eric Mittman | 5251 views | 11 replies |
kelleypb318499
It seems that using CAPTCHA would effectively negate spammers (though not humans using bogus e-mail addresses); thus, is there any simple way to forego the e-mail verification step without screwing up the whole application? That is, after registering you are immediately redirected to the protected page. Having to go and verify could turn off a lot of potential customers...
One way that you could do this would be to add in the update server behavior from the user confirm page to make the user automatically verified.
On the user registration page just after the insert user server behavior that ends around line 119 you would add in the update server behavior from the confirm page. Once this server behavior has been added you will need to update two parts of it, the trigger and the value for the userID. Here is what the updated code should be like:
// WA Application Builder Update
if (isset($_POST["Register_x"])) // Trigger
$WA_connection $localhost;
$WA_table "users";
$WA_redirectURL "";
$WA_keepQueryString false;
$WA_indexField "UserID";
$WA_fieldNamesStr "UserEmailVerified|UserVerificationCode";
$WA_fieldValuesStr "1" "|" "".WA_RandomPassword(20truetruetrue"")  ."";
$WA_columnTypesStr "none,none,NULL|',none,''";
$WA_comparisonStr "=|=";
$WA_fieldNames explode("|"$WA_fieldNamesStr);
$WA_fieldValues explode("|"$WA_fieldValuesStr);
$WA_columns explode("|"$WA_columnTypesStr);
$WA_where_fieldValuesStr "".$_SESSION['UserID']  ."";
$WA_where_columnTypesStr "none,none,NULL";
$WA_where_comparisonStr "=";
$WA_where_fieldNames explode("|"$WA_indexField);
$WA_where_fieldValues explode("|"$WA_where_fieldValuesStr);
$WA_where_columns explode("|"$WA_where_columnTypesStr);
$WA_where_comparisons explode("|"$WA_where_comparisonStr);
$WA_connectionDB $database_localhost;
mysql_select_db($WA_connectionDB$WA_connection);
  if (!
session_id()) session_start();
$updateParamsObj WA_AB_generateInsertParams($WA_fieldNames$WA_columns$WA_fieldValues, -1);
$WhereObj WA_AB_generateWhereClause($WA_where_fieldNames$WA_where_columns$WA_where_fieldValues,  $WA_where_comparisons );
$WA_Sql "UPDATE `" $WA_table "` SET " $updateParamsObj->WA_setValues " WHERE " $WhereObj->sqlWhereClause "";
$MM_editCmd mysql_query($WA_Sql$WA_connection) or die(mysql_error());
  if (
$WA_redirectURL != "")  {
    if (
$WA_keepQueryString && $WA_redirectURL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "" && sizeof($_POST) > 0) {
$WA_redirectURL .= ((strpos($WA_redirectURL'?') === false)?"?":"&").$_SERVER["QUERY_STRING"];
header("Location: ".$WA_redirectURL);
Once that part is done the next part would be to update the email message to remove the link and let the user know that they are registered. To do this you will need to edit the WA_Universal_Email > Email_Templates > registration.php. In here update lines 8, 9 and 10. Remove the code on these lines and put in your own message to the new users.
<p>Please follow the link below in order to verify this email address:</p>
<p>
<?php echo($WAGLOBAL_Root_URL); ?>users_Confirm.php?ID=<?php echo(mysql_insert_id()); ?>&code=<?php echo($_SESSION['randomConfirm']); ?>
If you have a good working setup currently you should make sure to backup the files so that you can revert back if your updates don't work out.
kelleypb318499
Thank you, Eric; that did the trick. Only other thing to do is change the ThankYou.php message about checking your e-mail. Cheers!
Good catch, thanks for posting back with that.
kelleypb318499
Only one problem: now I can't get beyond the users_Profile.php page and proceed to the protected page because it insists that I verify the email address...
The update to the registration page should be updating the UserEmailVerified column for the newly registered user. It should be setting the column to 1. What is the value of this column when you check it for the new user?
When this column is set to one it should get you past any of the checks for a verified user. Please post back with what you discover for this and also include a copy of your updated page so that we can take a look to see if we can spot any problems.
kelleypb318499
The setting under "Type" is tinyint(1); the setting under "Default" is 0.
kelleypb318499
This is the updated code from my user_Registration.php page. I tried changing the "Default" value to "1" but it still won't let me proceed to the protected page...
kelleypb318499
Now I'm getting PHP errors when registering new members. I'm overwriting all files to the default and will try again...
Ok, let us know if there are any issues after trying this again. When I was asking about the value in the db I was looking for the value of the particular user you had registered with. If the user has a 1 on the UserEmailVerified column then they should pass any checks for verified users.
