str_replace on data insert hidden field
Thread begun 3/18/2010 3:13 am by henk303241 | Last modified 3/19/2010 12:01 pm by Eric Mittman | 5323 views | 5 replies |
henk303241
Hi there,
I have 2 fieds in my database "page" and "url" (hidden field).
URL gets the data on insert from the PAGE form field:<?php echo((isset($_POST["page"]))?$_POST["page"]:"") ?>.
How can I accomplish a str_replace on this field.
I want to convert te page, for instance "is this a test?" to "this_is_a_test_".
I played around in the source with . "".((isset($_POST["page"]))?$_POST["page"]:"") ."" . but nothing I tried works :(.
Please help
You will need to do this in the insert server behavior for the field values string.
((isset($_POST["page"]))?str_replace(" ", "_", $_POST["page"]):"")
If you have any difficulty with this post back with the page in question.
henk303241
Allright!
This did the trick.. but, if you want to replace more characters like &, ?, and -?
You can compound the str_replace function calls to replace multiple characters like this:
str_replace("&", "_", str_replace(" ", "_", $_POST["page"]))
This would replace any "&" characters with an underscore and replace any spaces with an underscore. There might be some better ways to do this in php but this should do the trick for you. Here is a link to the functions page on the php site for more info:
php.net/str_replace
henk303241
Thanks for putting me on the right track. If you put it in an array it's shorter:
str_replace(( array(" ", "+", "&", "-", "'", "?")),'_',
Maybe this is helpful to somebody else.
Nice work, that is much cleaner.
