PowerStore 3 and CSS MenuWriter
Thread begun 3/17/2010 5:15 pm by a2d | Last modified 4/19/2010 4:59 pm by Eric Mittman | 3862 views | 5 replies |
a2d
I checked the posts and did everything noted:
showpost.php?p=42499&postcount=6
But I continue getting the same database error (see attached photo).
Basically what I want to do right now is change the category of the menu to bubble and that's it.
I changed back lines 2 & 3 in the menu.php in the CSSMenuWriter\cssmw_home\ folder as well as copy the updated treexml.xml file with no luck. Code below, but I did not need to change.
$WA_localRoot = "" .$WAGLOBAL_localRoot ."";
$WA_remoteRoot = "" .$WAGLOBAL_remoteRoot. "";
Can someone point me in the right direction.
Thank you,
Ernie
I have opened a ticket for you on this issue. To check the status of your ticket or update it login and visit your support history.
pizzicaluna381282
i have the same problem
i have the same problem, published the solution please
Looking at the ticket it looks like the issue was resolved with the updated treexml.xml file located in this post:
Please give this a try and let us know if you experience any further issues with this.
pizzicaluna381282
does not work
//Getting tired of WebAssist, sell software that does not work. I lose hours adjusting your mistakes. Solve the problem immediately//
Sorry not a software problem. The instructions do not specify that after installation, to change the parameters of the menu should re-download all your online site.
Sorry again
I have opened a ticket for you.
