Where does this border come from?
Thread begun 3/17/2010 8:35 am by dan361748 | Last modified 3/17/2010 11:29 am by Eric Mittman | 1255 views | 1 replies |
dan361748
Wondering if someone can point me in the right direction. Where does this border come from? I've created the form in Form Builder and I can't identify the CSS source of the border around the form...even when I inspect if from Firebug. It always seems to be there in my Form Builder forms. Please see attached. Many thanks!
The border is not explicitly defined within the css, it is there by default when the <fieldset> tag is used. If you would like to get rid of the border you need to set the border to none in the following style:
form.NewFromBlank_Default fieldset.NewFromBlank_Default {
border: none; /*add in this attribute to get rid of the border */
clear:both;
If you have a different style applied to your field set you will need to add this attribute to that style.
