Variable to control $recipientEmail
Thread begun 3/16/2010 3:32 pm by leifbaker378532 | Last modified 3/25/2010 4:40 pm by Jimmy Wu | 5858 views | 9 replies |
leifbaker378532
Your extensions work great. I have built a simple submission form requiring name, email address and a location from a dropdown menu (a US state: strcmp). I would like to send the completed form to a different recipient depending on which state(s) are chosen - as if to different sales reps in different regions.
Can anyone tell me how to correctly do this? I think I know how conceptually, but I can't get the syntax right.
Any help will be appreciated.
Thanks,
Leif Baker
Jimmy Wu
What do you have so far for setting this up? You will want to set the $RecipientEmail to be different based on the different state. How is the state set up? Is it from a form and is the form's method post?
leifbaker378532
It's a POST
Now the recipient is :
_______________________________________________________________
if ((($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST))) {
//WA Universal Email object="mail"
//Send Loop Once Per Entry
$RecipientEmail = "leifbaker@nj.rr.com";include("WA_Universal_Email/WAUE_forms_1.php");
_______________________________________________________________________
while the states come from a drop down list, like here:
__________________________________________________________________________
<option value="AL" <?php if (!(strcmp("AL", (isset($_GET["invalid"])?ValidatedField("forms","Contact_me_group_State"):"")))) {echo "selected=\"selected\"";} ?>>Alabama</option>
I've included the form page as a PDF file.
Any help you can give me will be appreciated.
Thank you,
Leif Baker
Jimmy Wu
Ok, so you will want to have an switch statement based on the post value of the drop down list. Basically you'd want to set up a switch statement:
control-structures.switch.php
switch((isset($_POST["select"]))?$_POST["select"]:"") {
  case "AL":
    break;
You would want a different case for each of the states.
leifbaker378532
Thanks, but ...
... i"m afraid I still can't get it to work
I tried like this -
//$RecipientEmail = "leifbaker64@hotmail.com";include("WA_Universal_Email/WAUE_forms_1.php");
case "AL":
break;
case "AK":
break;
case "AZ":
$RecipientEmail = "leifbaker64@yahoo.com";include("WA_Universal_Email/WAUE_forms_1.php");
break;
//Send Mail All Entries
if (""!="") {
header("Location: ");
but that didn't work.
I tried a couple other ways, also , with equal results (none).
Can you tell me exactly how I should set this switch up?
Thanks,
Leif Baker
Jimmy Wu
Its possible that the select list value isn't being populated correctly or we're not reading it correctly. Try putting this above the code switch code:
die((isset($_POST["select"]))?$_POST["select"]:"not set");
this will cause the select list value to be output when the form is run.
leifbaker378532
Thanks, but that's not it
That merely makes the page return "not set".
I made a simpler version of the form. I've attached it as a PDF.
There's got to be a simple way to do this that we're overlooking.
It's probably a syntax error on my part.
I didn't think it would be so complicated. But I'm grateful for you efforts.
Any help you or anyone can give me will be greatly appreciated.
Thanks again,
Leif Baker
Jimmy Wu
Sorry, I think the first time I sent you the code, I looked at the wrong form, so I sent you the wrong code. The select list name is "Contact_me_group_State", so you'd want to get the post variable with that, not the "select" post variable. That is why the variable is not set.
In the switch statement, try using this instead:
switch((isset($_POST["Contact_me_group_State"]))?$_POST["Contact_me_group_State"]:"") {
You can take out the testing code I sent you earlier:
leifbaker378532
You da man...
that did it.
Thanks for all your help.
Jimmy Wu
Great to hear it. If you run into any additional issues, feel free to open a new thread.
