Paypal Not processing and other errors
Thread begun 3/16/2010 5:49 am by ronald_franklin366888 | Last modified 3/18/2010 8:13 pm by Dani Chankhour | 3520 views | 6 replies |
I have been trying to test my store and it comes up with
"Transaction Not Completed
We're sorry
Your PayPal transaction could not be completed. Please return to checkout and try again."
This keeps happening on each item.
Also when i choose an item option from the drop down menu it says that item is not available online. Why is that?
www.driftbuildstore.com
I only have products in the Turbo's, Intercooler (Treadstone), and Blow Off Valves (TurboSmart).
Can someone please help?????
Also is there a way to set an item up so that it comes up in several categories?
Dani Chankhour
make sure that you are using the right credentials in the setting tab in the admin area. and make sure to use the test credentials if you are testing or the live credentials if you are not using the sand box.
In PS3, on the product update page, you could select multiple categories for each item so it shows up under multiple categories.
Originally Said By: Dani Chankhour
Thanks for your response. What do you mean test credentials and live credentials? When i set it up is just asked for my user and password Signature.
i.edwards384429
error
Hi
I and others have had issues with paypal which in my case were resolved by modifying as follows.
It has been sent to the geeks to see if it's a bug ;-)
function WA_PP_ECO_CallSOAP($sXML, $useSB) {
$soapObj = new WAPPECOSOAPObject;
$soapObj->soapURL = "https://api-3t.paypal.com/2.0/";
if ($useSB) {
$soapObj->soapURL = "https://api-3t.sandbox.paypal.com/2.0/";
I changed them to this (I commented out the PayPal sandbox URL, and the URL is now universally set to the PayPal non-sandbox URL):
if ($useSB) {
// $soapObj->soapURL = "https://api-3t.sandbox.paypal.com/2.0/";
HTH
Ian
Dani Chankhour
Originally Said By: ronald_franklin366888
When you set up you paypal account you are giving the user, pass, and signature for your live account. In addition, you can create a user, pass, and signature to test with.
Do you have the testing user, pass and signature or are you just using the live one?
I am justing using the Live one. Is that a bad thing?
Dani Chankhour
No, using live account should be OK.
It seems that this is a bug with PowerStore. To fix this issue, change this line in your checkout.php file from:
$WA_PP_ECO_Set_params[1][$nextIndex] = "".($WAGLOBAL_Paypal_Sandbox == 1)?"true":"false" ."";
to
$WA_PP_ECO_Set_params[1][$nextIndex] = "false";
and then change this line on your pp_confirm.php file from:
$WA_PP_ECO_GetResult = WA_PP_ECO_Get_Post("".$WAGLOBAL_Paypal_User ."", "".$WAGLOBAL_Paypal_Password ."", "".$WAGLOBAL_Paypal_Signature ."", ($WAGLOBAL_Paypal_Sandbox == 1)?"true":"false". "");
to
$WA_PP_ECO_GetResult = WA_PP_ECO_Get_Post("".$WAGLOBAL_Paypal_User ."", "".$WAGLOBAL_Paypal_Password ."", "".$WAGLOBAL_Paypal_Signature ."false");
This will make sure that powerstore is always using the right url to post to.
