How can I modify visitors_EmailPW page?
Thread begun 3/15/2010 11:18 am by donald.dickson338135 | Last modified 3/24/2010 11:52 am by Jimmy Wu | 1304 views | 3 replies |
Hello - can you tell me how to modify the visitors_EmailPW page so that after the email is sent the user is redirected to a new page? I realise that I should have set this up when using the SA wizard, but at the time the appropriate page for the redirect was not made so I left the field blank. (step 6 on page 3). Stupid of me I know!
At present the send email with the PW details works (the email is sent to the user OK) but the page reloads after clicking the send button leaving the user with no indication that the mail was sent.
Is there a property that can be modified or a place in the code on visitors_EmailPW where I can insert a new line or modify an existing line?
This is an Oops on my side, but if you can help that would be fine.
Many thanks
Don
Jimmy Wu
If you look on the page, and open the Server Behaviors panel, you should see a SecurityAssist Email Password line. Double click on that and you should be able to run through the setup for emailing the password and set the fail or success forward pages there.
Advice worked just fine
Hello Jimmy, thank you for the advice. I have been out of action for a few days with flu but have now implemented your suggestion using the Server Behaviors panel and everything is working fine.
Much appreciate the support.
Best wishes
Don
Jimmy Wu
Great to hear it. If you run into any additional issues, feel free to open a new thread.
