CSS Messing With Images
Thread begun 3/15/2010 10:23 am by andy245039 | Last modified 3/15/2010 5:29 pm by Jimmy Wu | 3374 views | 5 replies |
andy245039
I have created a new template that includes a header and footer call. The problem that is driving me crazy is that somewhere in one of the css sheets there is a call to create a space I believe below a <TR> can anyone tell me where that call is?
See the attached image as an example
neilo
Can you post a link to a page where we can see and diagnose this problem?
andy245039
Css Space
I don't have the site up as I am still running it on my local test server. I do know that the source code does not display any spacing and it looks fine in the design mode of Dreamweaver. So I am thinking that it must be a call from the common.css or default.css but for the life of me I can't seem to pin point it.
Jimmy Wu
What browser are you looking at the page in?
Also, can you post up the page that you are getting this layout error in so I can take a look at it?
andy245039
I am Looking at it in both Safari and Firefox - both are showing the same issue.
Here is the link to the page that I have put up Logo isn't showing because it is using a full path on my testing server which I just realized that powerstore doesn't use the path from the directory root.
contactus.php
Thanks in advance for your help. I don't usually program with DW templates i usually use header and footer php calls. I don't know if this is because of the template but I am sure that it has to do with a css rule somewhere.
Andy
Jimmy Wu
For the bottom of the area, if you set the line-height to 2px then it seems to show up correctly. And for the top if you set the td to have style="line-height: 0px; height: 1px;" the top seems to show up correctly.
As for the general layout of your page, you shouldn't use a table to layout your page. You should use divs to layout the page. If you used divs, you shouldn't have this issue. Tables should only be used to display data.
