applyServerBehavior error in Multiple Record Inserts
Thread begun 3/15/2010 10:01 am by dinohorn397192 | Last modified 3/16/2010 12:06 pm by Jason Byrnes | 3556 views | 5 replies |
dinohorn397192
I keep getting this error when trying to apply Multiple Record Insert.
While executing applyServerBehavior in WADA_MultiInsert.htm, a JavaScript error occured.
I'm following the online video tutorial exactly...
insert_multiple_final.swf
Any suggestions?
php is attached.
try deleting the Dreamweaver cache file from the users configuration folder:
dinohorn397192
I closed Dreamweaver, deleted the webcache file, then restarted Dreamweaver. I'm still getting the same error message. But I did notice it was adding it to my server behaviors. (attached pic). I can open that behavior up and do edits, but when I "finish" it give me the same error. The form won't submit.
Thanks for the quick reply.
dinohorn397192
Update:
I started over without a Template, hand made the form instead of CSS form builder.
I don't get the error when I use Multiple Insert, but still haven't figured out why it's not inserting into db.
dinohorn397192
I was able to get it to work. It seemed weird. In the "configure bindings" area, I had to assign a repeating field to make it work. Before I was putting all static data in, except for the primary key to test.
Ok, glad to hear it is working
