PS3 Install Issues
Thread begun 3/14/2010 9:59 pm by Wasntme | Last modified 4/21/2010 10:39 am by Jimmy Wu | 4413 views | 9 replies |
Wasntme
PS3 Install Issues
I am trying to install PS3 and the first error i got was "creative view" to fix that i download the known issues fix and then re-upload everything again. now when i run the install i get passed the first step and then get a "Internal Server Error" The server encountered an internal error or misconfiguration and was unable to complete your request.
the link is
online.fitnessphyre.com.au.
Thank you
Jimmy Wu
Have you checked the server error log or asked your server admin to check to see what the error is?
Wasntme
I looked into the server error log and found nothing...I am only getting this error after I did the creative view fix updates...
Wasntme
this account is part of my reseller account so i would also be the admin (LOL).
Jimmy Wu
If you are the server admin, are you able to allow create view privileges for your user? If you aren't getting the create view error, you do not have to make the create view known issue update.
Wasntme
Can PS3 be installed on a subdomain?
I up loaded the same files on 2 different domain names. one on the root of the domain and the second one in the subdomain. The one installed on the root of the domain worked fine where as the 2d one on the subdomain is giving me the error...
davas56386677
Hi
There are no limitations to upload and run the installation of Powerstore 3 on a subdomain.
What type of error did you get when installing it on your subdomain ?
Dan
Jimmy Wu
As Davas said, installing the PowerStore multiple times on a single server but using different directories should be fine. What are the permission settings for the directory you have installed the store in the second time?
Wasntme
Not sure what changed but it seems to work after I deleted all files and reinstalled.
Thanks for the help.
Jimmy Wu
Great to hear you were able to get it working. If you run into any additional issues, feel free to open a new thread.
