Problem uploading images
Thread begun 3/14/2010 7:38 pm by bruce379400795 | Last modified 4/07/2010 7:35 am by bruce379400795 | 1859 views | 2 replies |
bruce379400795
I know this is not using DFP, but I figured I could get a good response on here. I am building a form to upload an image to a folder (c:\wamp\www\theworkoutstore\images\). I also want to store the filename of the image into my MySQL database like so: images/filename. I cannot get the filename into my database column by trying to use a hidden field and putting the filename into it to submit to the database. I figured using <?php $file ?> in the hidden field would do it, but I also need "images/" to be in front of the filename. As of right now the only thing that is inserted into my database from the hidden field is "insert". I'm lost. Any suggestions? Here is my code:
<?php require_once('Connections/connect.php'); ?>
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
$editFormAction = $_SERVER['PHP_SELF'];
if (isset($_SERVER['QUERY_STRING'])) {
$editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "uploadImage")) {
$insertSQL = sprintf("INSERT INTO workout (Name, Image) VALUES (%s, %s)",
GetSQLValueString($_POST['Workout_Name'], "text"),
GetSQLValueString($_POST['Image'], "text"));
mysql_select_db($database_connect, $connect);
$Result1 = mysql_query($insertSQL, $connect) or die(mysql_error());
// define a constant for the maximum upload size
define ('MAX_FILE_SIZE', 102400);
if (array_key_exists('upload', $_POST)) {
// define constant for upload folder
define('UPLOAD_DIR', 'C:/wamp/www/theworkoutstore/images/');
// move the file to the upload folder and rename it
// replace any spaces in original filename with underscores
// at the same time, assign to a simpler variable
$file = str_replace(' ', '_', $_FILES['image']['name']);
// convert the maximum size to KB
$max = number_format(MAX_FILE_SIZE/1024, 1).'KB';
// create an array of permitted MIME types
$permitted = array('image/gif','image/jpeg','image/pjpeg','image/png');
// begin by assuming the file is unacceptable
$sizeOK = false;
$typeOK = false;
// check that file is within the permitted size
if ($_FILES['image']['size'] > 0 && $_FILES['image']['size'] <= MAX_FILE_SIZE) {
$sizeOK = true;
// check that file is of a permitted MIME type
foreach ($permitted as $type) {
if ($type == $_FILES['image']['type']) {
$typeOK = true;
break;
if ($sizeOK && $typeOK) {
switch($_FILES['image']['error']) {
case 0:
// make sure file of same name does not already exist
if (!file_exists(UPLOAD_DIR.$file)) {
$success = move_uploaded_file($_FILES['image']['tmp_name'], UPLOAD_DIR.$file);
else {
// get the date and time
ini_set('date.timezone', 'America/Virginia');
$now = date('Y-m-d-His');
$success = move_uploaded_file($_FILES['image']['tmp_name'], UPLOAD_DIR.$now.$file);
if ($success) {
$result = "$file uploaded successfully";
else {
$result = "Error uploading $file. Please try again.";
break;
case 3:
default:
$result = "System error uploading $file. Contact webmaster.";
elseif ($_FILES['image']['error'] == 4) {
$result = 'No file selected';
else {
$result = "$file cannot be uploaded. Maximum size: $max. Acceptable file types: gif, jpg, png.";
<head>
<title>Administrator Section - Insert</title>
<style type="text/css">
body,td,th {
font-family: Calibri;
font-size: 11pt;
color: #000000;
.style1 {
color: #FFFFFF;
font-weight: bold;
font-size: 16pt;
.style2 {color: #FFFFFF}
</style></head>
<body>
<table width="800" border="0" align="center" cellpadding="0" cellspacing="0">
<tr>
<td width="800"><img src="images/banner.png" width="1000" height="200" /></td>
</tr>
<tr>
<td bgcolor="#000033"><div align="center"><span class="style1">ADMINISTRATOR SECTION</span></div></td>
</tr>
<tr>
<td><table width="100%" border="0" align="center" cellpadding="0" cellspacing="0">
<tr>
<td width="20%" valign="top" bgcolor="#000033">&nbsp;</td>
<td width="80%" valign="top"><br />
<table width="60%" border="1" align="center" cellpadding="5" cellspacing="0" bordercolor="#000000">
<tr>
<td bgcolor="#CCCCCC">
// if the form has been submitted, display result
if (isset($result)) {
echo "<p><strong>$result</strong></p>";
<form action="<?php echo $editFormAction; ?>" method="POST" enctype="multipart/form-data" name="uploadImage" id="uploadImage">
<p>
<label for="Workout_Name">Workout Name:</label>
<input type="text" name="Workout_Name" id="Workout_Name" />
<label for="image"><br />
<br />
Upload Image:</label>
<input type="hidden" name="MAX_FILE_SIZE" value="<?php echo MAX_FILE_SIZE; ?>" />
<input type="file" name="image" id="image" />
<input name="Image" type="hidden" id="Image" value="<?php echo $file ?>" />
</p>
<p align="center">
<input type="submit" name="upload" id="upload" value="Upload" />
</p>
<input type="hidden" name="MM_insert" value="uploadImage" />
</form>
</td>
</tr>
</table>
<br /></td>
</tr>
</table>
</td>
</tr>
</table>
</body>
</html>
Dani Chankhour
Think you need to use
instead of
$_POST['Image']
to get the image name. and then you could just concatenate the folder name to it.
bruce379400795
Thanks for the help. I got it to work.
