Search Using Radio Buttons
I'm have trouble working out how to use radio buttons with the Search SB.
Basically I have a form with three radio buttons named "status", one labeled "Used" one labeled "Not Used" and one labeled "All". All three of these will check the one database field, "fldInvNum". If the user selects "Used" it checks for a null value, if the user selects "Not Used" it checks the same field for not null and if the user selects "All" then it returns all records.
When adding the parameters to the Search SB, under filter type, there doesn't seem to be an option for a radio button.
