Insert Swf Image or FLV
Thread begun 3/14/2010 1:35 pm by massimo173451 | Last modified 4/05/2010 1:09 pm by massimo173451 | 4722 views | 7 replies |
massimo173451
Hi there, I need to insert in the index page (header) a SWF file or FLV and center it on background image, which is the right manner for accomplish this operation (creating a div tag or what else??). I have used the method showed in this link www.tessyacconciature.it, just another question I have insert a link for facebook (in the footer) but I have a vertical bar on right image how possible delete it?
Regards:
Massimo
Jimmy Wu
I can't access that link you posted, but inserting flash into an html/php page should be pretty simple. Here is a tutorial on how to do it:
flash_inhtml.asp
I'm not sure what you mean by a vertical bar on the right image, could you post a link to your site so I could have a look?
massimo173451
Thank you Jimmy, the site is online again, in the footer I have insert a div tag for Facebook link and other social Network, now if you check the background image in grey is broken at end (in the original template was complete), now how is possible apply this new behaviour in the template file with complete image in background?
Massimo
Jimmy Wu
Try adding the div into the footer, instead of outside of the footer. The image is in the footer, and if the footer is cut off, then the background image is as well.
massimo173451
Jimmy, I have added the swf in the storeMessage div, but when resize the window in the browser the swf file is not centred, have you a suggestion for fix this issue??
Massimo
neilo
For the facebook image in the footer, no need to bother with divs, just go to the admin CMS and add it to the Page Name: Admin Template Content Area: Footer (about half way down the update content first page. Insert image, (give it position 'Abs Middle') and then add the link as normal. Logo inserted, and css style added. Image attached.
i.edwards384429
flash effect
Just wondered how you got the page curl on the site you listed.
I'm assuming it's a background flash image?
cheers
Ian
massimo173451
Edwards, I have insert AP div and then inside it the swf file with fixed background image in the storeMessage , but when resize the windows the swf is not centred.
Neilo after modify as your suggestion (I have modify the Main.dwt) the facebook image link is not visible as showed in the snapshot.May you send me the sample code pls or explain it in details?
