Can I chart with a varchar column?
Thread begun 3/13/2010 1:24 pm by dinohorn397192 | Last modified 3/16/2010 4:01 pm by Jimmy Wu | 3944 views | 6 replies |
dinohorn397192
I have a pet table that has a column for type (e.g. PetType). It will contain either "Dog" or "Cat". I'm trying to create a pie chart of this column. I only see one of the values in the top left area of the chart (e.g. "Cat") and only a "-" in the middle of the chart.
dinohorn397192
I have added some screenshots.
Jimmy Wu
I can't actually see the screenshot very clearly, so I'm not sure what settings you've set, but you should be able to use the values to set up a pie chart. Did you set the petType as the X Label or the Y Label and what did you set for the other label that isn't set to petType?
dinohorn397192
I attached a better screenshot. My Data Source X Label is PawsType and my Y Value is PawsType. Group by Value.
This is my code.
<?php if(!isset($_SESSION)){session_start();}?><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
</head>
<body>
<object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0" width="320" height="240">
<param name="movie" value="../DynamicWebCharts/open-flash-chart.swf?data=../DynamicWebCharts/Data/graphtest_dataparser3.php?<?php echo (isset($_SERVER['QUERY_STRING'])?"GET=".str_replace("&","§",$_SERVER['QUERY_STRING']):'');?>" />
<param name="quality" value="high" />
<embed src="../DynamicWebCharts/open-flash-chart.swf?data=../DynamicWebCharts/Data/graphtest_dataparser3.php?<?php echo (isset($_SERVER['QUERY_STRING'])?"GET=".str_replace("&","§",$_SERVER['QUERY_STRING']):'');?>" quality="high" pluginspage="http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" width="320" height="240"></embed>
</object>
</body>
</html>
Jimmy Wu
The x-label can be specified as a string column, but the y-label has to be a number column. If you change the y-label to another column, like the id column, and change the calculation to Count, you should get the result you were looking for.
dinohorn397192
Thanks! It worked.
Jimmy Wu
Great to hear it. If you run into any additional issues, feel free to open a new thread.
